Pinpointing squeaky suspension noise can make you pull your hair out; especially if everything visually looks ok.
Sway bar links are very common. I've seen the sway bar bushings get noisy, I've seen noisy ball joints(Just had one in the shop that had a lower ball-joint making all sorts of noise)...., but usually it's the control arms. Did you make sure they car was loaded when your torqued the control arms?
The "check the forum and guess method get's pretty" expensive.
The best way to isolate the noise it try and get under the car with a stethoscope, but that means you'll literally need ramps. Once its's high enough off the ground to crawl underneath, you need a buddy or two to bounce the car while you poke around with the stethoscope. They sell automotive stethoscopes @ the parts for like $20.
A step further is to use a chassis ear. It's literally a set of microphones that you attach to different parts of the suspension and drive the car around. You can switch channels and really dial in the noise. The new ones interface with your phone. Kinda pricy for DIY stuff though.
