I thought it was best to start a clean one, with all facts.
Haven't had the issue for a long time, but now it's back.
I hope, some one can point me in the right direction
When?
I believe that the lack of adaptation plays a role, as the issue comes after flashing the car.
I have observed the issue on both stock ECU tune and EPL stage 2.
The issue was there when the car was single pulley and now that it's dual pulley.
Manual downshift followed by light/medium acceleration is where it usually happens.
The issue seems to be triggered at mid range rpm (3300 - 4200) and part throttle.
Parts shuffling
I have moved injectors, plugs and coil packs around multiple times.
Misfire never occurred on any other cylinder than #6
Coolant leak
I never found evidence of IC leaking from supercharger or level dropping.
New ICs have now been installed in the supercharger
New gaskets everywhere (IC, SC, injectors) and new PCV.
Plugs
The plugs never looked hot or fouled.
New NGK PFR8S8EG gapped down to .026 installed multiple times.
Compression
#1 182
#2 179
#3 188
#4 182
#5 182
#6 184
Carbon buildup
Car has just been walnut blasted, clean as a whistle.
Exhaust and cats
Stock cats, 2.5" downpipes without baby resonators
Cat cores looked ok on a borescope, but I believe it's hard to tell (angle/image quality...)
Car just cleared MOT where the exhaust fumes are analyzed (NOx, CO, HC, CO2, O2).
Filters
New air filter and fuel filter (and LPFP)
Code:
6355 - Cylinder 6 P0306 00 [096] - Misfire Detected Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 190753 km Date: 2022.04.20 Time: 19:48:47 Engine RPM: 3808.00 /min Normed load value: 25.1 % Vehicle speed: 32 km/h Coolant temperature: 102 °C Intake air temperature: 49 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 13.609 V Unlearning counter according OBD: 40 Engine speed: actual: 3840 /min MAF_ENVD: 315.92940 mg/stroke Coolant temperature (unfiltered): 102.75 °C Engine: operating status: PL T_AST_ENVD: 77.10 s Vehicle speed: actual: 32 km/h 7948 - Cylinder Disabling P130A 00 [096] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 190753 km Date: 2022.04.20 Time: 19:48:47 Engine RPM: 4032.00 /min Normed load value: 39.2 % Vehicle speed: 34 km/h Coolant temperature: 102 °C Intake air temperature: 49 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 13.710 V Unlearning counter according OBD: 40 Engine speed: actual: 128 /min MAF_ENVD: 0.00000 mg/stroke Coolant temperature (unfiltered): 101.25 °C Engine: operating status: ST T_AST_ENVD: 0.00 s Vehicle speed: actual: 0 km/h
