Results 1 to 3 of 3
    Mar 21 2021
    Ventura County, CA
    Anybody experience the P0507 high idle check engine light? Tune related?
    After going Unitronic Stage 2 E85 my 2018 RS3 threw the P0507 (idle control system has excessively high RPM) code a few weeks after, not sure if it was related to the tune or strictly coincidence, the car idled perfectly so I cleared the code and it never came back. Fast forward a few months later, I'm Stage 3 E85 now and it just threw the same code yesterday while I was idling in my garage. My idle is perfect, doesn't hunt, surge or anything, idles around 800 in comfort and 1100 in dynamic/sport.
    Has anybody else had this code pop up? Is there some kind of idle relearn procedure I can try? Possibly my Unitronic 4" CF intake causing it?
    Thanks guys, any input is greatly appreciated.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Ive seen that code on a failing PCV on other vehicles
    Stage 1 more than you RS3
    Mar 21 2021
    Ventura County, CA
    A little update, this little hose right here was the culprit. I guess when I removed it to install my injectors to go Stage 2 the twisting action made a tear in it underneath which I couldn't see, this caused a tiny leak and increased my idle just enough to trip the CEL. Replaced it and now all is perfect!
