Results 1 to 19 of 19
    Senior Member Two Rings AccordingToAlex's Avatar
    Oct 04 2019
    SF Bay Area
    Spare tire question for those who have OEM 20s
    Hi all,
    For those who have an A/S5 that came with OEM 20s, do you have a 20" donut in the back? If so, any idea what part number it is? If not, what is in its place? Thank you
    Jul 16 2018
    Atlanta
    The B9 spare wheel is a 19x4 compact.
    8W0 601 027 C for steel.
    8W0 601 027 E for aluminum.
    None of the brake systems on the B9 require a 20" wheel that I know of.
    D5 420mm ceramic requires 20", but the B9 ceramic is only 400mm.
    The B9 era workshop manual fails to document these specifications.
    Veteran Member Three Rings Andy_FL's Avatar
    Mar 01 2004
    South Florida
    Quote Originally Posted by AccordingToAlex View Post
    Hi all,
    S5: I have a 19" donut, as Smac770 commented.
    Oct 04 2019
    SF Bay Area
    Thanks guys. I guess what I'm trying to wrap my head around is how it is possible to use a 19" spare with 20s. Wouldn't that fry the Quattro? Or do they put taller tires on the models that came with 20s?
    Apr 05 2012
    Earth
    Yes, it has a taller side wall. The circumference of the spare tire is the same as the OEM 20" wheel.
    Senior Member Three Rings CurvesAhead's Avatar
    Feb 07 2020
    Earth
    Here is what came with my car: A LingLong T125/75R19. More info in your other post under Wheels and Tires. The sidewall on the 19 inch spare does not appear taller that the 20 inch tire that came on the car.
    2019 Audi S5 Prestige
    Jul 16 2018
    Atlanta
    All the B8 and B9 cars have the same target tire diameter. That's why the lower profile tires on the larger wheels. 245/40 for 18 but 245/35 for 19, etc.
    The allroad is +1" vs the non-allroad cars. Ie, 245/45r18 rather than 245/40r18, etc. Thus it uses a different spare, 175/55r19 expandable on 19x6. The expandable aspect allows it to fit in the same spare tire well but inflate to match the +1" main tires.
    Dec 01 2011
    i have an S5 with the factory 20" wheels, and i also have that same spare, LingLong T125/70/19. the 125/70 is thicker than the stock 265/30, the overall diameter ends up about the same so it's not an issue. it will not damage anything using it as a temporary spare.
    IG @theshawon
    Feb 07 2020
    Earth
    Quote Originally Posted by Liquid Smoke View Post
    Thanks for confirming the spare is adequate for the S5 with twenties.
    Jul 16 2018
    Atlanta
    Quote Originally Posted by CurvesAhead View Post
    unloaded new diameter comparison
    mains:
    (2*245*0.40)/25.4 + 18 = 25.72"
    (2*245*0.35)/25.4 + 19 = 25.75"
    (2*255*0.35)/25.4 + 19 = 26.03"
    (2*265*0.30)/25.4 + 20 = 26.26"
    spare:
    (2*125*0.70)/25.4 + 19 = 25.89"
    So you see how the spare straddles the center ground between the various sizes.
    As for is that ok, let's consider your tires at new. So:
    axle 1: (25.89"+26.26")/2 = 26.075 average.
    axle 2: (26.26"+26.26")/2 = 26.26" average.
    non-haldex quattro requires a 2mm max tread depth average diff between the two axles. That's on both sides of the tire, so 4mm max diameter diff, or .1575". But yours would be .1850". So yeah, on brand new 265/30, the spare would seem a bit too small. Drop the pressure in the mains a tad? The real problem is these are unloaded new diameters. Who knows what your real rolling diameter is, as that'll vary with tire wear and tire pressure and current vehicle load.
    But since the spare limits you to 50 miles at not more than 50 mph, I wouldn't stress about it.
    Feb 07 2020
    Earth
    Quote Originally Posted by Smac770 View Post
    mains:
    spare:
    Thank you Smac770 for posting the numbers and explanation concerning the spare, like you said: we should be fine.
    Oct 04 2019
    SF Bay Area
    Got it. So after reading all this wonderful information, the conclusion is: Flatbed LOL. These RS5 rotors have 275/30s on them which would make them 26.5" in diameter, which is an almost 15.5 mm difference from the spare diameter. Thanks again everyone, in really do appreciate all your input and information!
    Apr 05 2012
    Earth
    I had my RS5 with 20” OEMs get a flat tire and I used the temporary spare and drove over 30 miles on it without any problems.
    Oct 04 2019
    SF Bay Area
    Quote Originally Posted by JohnEnglish View Post
    Interesting! I thought all RS5s came with fix-a-flat and no spare?
    Jul 16 2018
    Atlanta
    There is no spare tire/wheel part in the B8 RS5 catalog. There is one in the B9 RS5 catalog.
    Oct 04 2019
    SF Bay Area
    What's the part number? 8W0 601 027?
    Jul 16 2018
    Atlanta
    I posted in the second post. ...027 C for steel, ...027 E for aluminum.
    The B8/B9 spares come in three PR codes:
    1G5 - steel
    1G6 - aluminum
    3F1 - expandable
    The 1G6 is specific to the RS models, but it's only for weight. Same physical dimensions and same tire, Hankook S300 T125/70r19
    B8 used the same T125/70r19 100M tire, but by Continental. I don't find the Hankook on Tirerack, but I do find the Continenal.
    But I wonder with those 275/30, if you might find the 3F1 for the allroad more interesting. I couldn't find the specs for the B9 version (8W9 601 010 B), but the B8 version was 175/55r19 expanded, or 26.58". The B9 should be the same, as it uses the same tire sizes as the B8. Also the benefit of 2" wider wheel and tire. Though still 50/50 limited as I understand it. Being an expandable, you would need the air compressor too, which you might already have if you have the 1G8 "road hazard repair kit" instead of an actual spare.
    Jul 16 2018
    Atlanta
    If I can ever find a not-temp use tire of suitable size and a wheel, I'll be happy to tell these temp spares off.
    For my 245/40r18, which my A4 brakes can handle 17",:
    175/65r17
    175/55r18
    175/50r19
    185/60r17
    185/55r18
    185/45r19
    195/55r17
    195/50r18
    195/45r19
    Even 175 might cause the cargo floor to sit a few mm up, but that's fine. 165 would be best. But you can't find a real tire that's narrow in 17" or 18".
    50/50 should be illegal.
    Jul 16 2018
    Atlanta
    Or just swap out the spare with a larger one:
    https://www.tirerack.com/tires/tires...omCompare1=yes
    26.4", assuming the extra 3/4" fits in the spare wheel well. (where do they expect you to put the dead full size tire if you're loaded up on a trip?)
