Results 1 to 11 of 11
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    Audi A4 b6 and Ignitron ecu
    Hi, i am starting this thread to invite all people versed in the ignitron ecu to join the discussion...i have a 2004 Audi A4 1.8t havily modified and i recently bought the ignitron ecu, the purpose of this thread is to share knowledge in order to get the best out of ignitron ecu in regards to the b6 platform...
    So. lets start the party...
    audi b6 owners using ignitron ecu check in pls!!!!!!
    BetaAlphaTau member #19
    Established Member Two Rings drifthero11's Avatar
    May 24 2020
    Boynton Beach Florida
    I'm in the process of locating one. Where did you buy yours?
    Sent from my SM-G965U1 using Audizine Forum mobile app
    Keep going faster.
    Nov 24 2004
    MOntreal
    Quote Originally Posted by drifthero11 View Post
    straight from ignitron, go to their web site and send them an email, very nice people
    Nov 24 2004
    MOntreal
    I need the oem ecu pinout if someone has it pls share it
    Jan 24 2010
    Paramus,NJ USA
    Plug n play in terms of wiring. Theres a setup wizard in the software to get your started. I am attaching a link to a pdf for AUM engine code but still me7.5 as well as some datasheets for various bosch sensors. Links expires in 5 days.
    https://we.tl/t-YggwKS1Mhr
    Ziddy Autowerks
    Nov 24 2004
    MOntreal
    Quote Originally Posted by EuroxS4 View Post
    I know it's plug and play, i am looking for pins to wire a fuel pressure sensor, looks like pin 26 but i am not sure, second i want an input where i can send a signal from aquamist to tell the ecu that meth is on and switch to race mode, different maps and more boost...now aquamist has a dedicated output for this but its 4.5v or 7v, i might have to tap into the aquamist + and get it from there because i am not sure if i can alter the voltage the ecu sees in order to trigger race mode..
    Sent from my LYA-L0C using Audizine Forum mobile app
    Nov 24 2004
    MOntreal
    Ditched the n75 in favor of mac, the rubber lines were so hard to remove so i went with quick connect and nylon lineIMG_20220422_140558.jpg
    Veteran Member Four Rings B5carl's Avatar
    Apr 29 2017
    2001 A4 1.8t AWM 5-speed Quattro(SOLD)
    Boston, MA
    Quote Originally Posted by 20vturbo View Post
    Hey man, quick question. Not trying to jack your ECU thread but I also plan on getting a Mac solenoid and confused on how you hooked yours up. Wouldn't the hose on the bottom of the diaphragm be pushing against it while it's trying to force it downwards?? From the way you hooked it up, it looks to be that way.
    Or does the valve stay shut and the boost pressure push it upwards while releasing air through the bleed in the front of the controller? I was gonna use a 4 port solenoid for a dual port wastegate but your set up looks interesting with the single port
    Nov 24 2004
    MOntreal
    Yes, i wired it according to a diagram online, if you apply pressure on top you keep it closed, while it is cycling i think this way you can be more precise, like having the valve just a bit open vs full open...but both ways should work....FB_IMG_1649879162067.jpg
    Veteran Member Three Rings wafi ahmed's Avatar
    Feb 03 2019
    Ny Long Island
    Noob question, If I get ignitron I have to be the one tuning it correct?
    Jan 24 2010
    Paramus,NJ USA
    Mostly unless you know of someone whos familiar with it. However I would think most tuners would be in the vw/audi scene. Also don't forget they have a facebook group and alot of people share some information on there. Lots of pepople in europe running this standalone in their VAG vehicle in europe. It is for the serious user.
    Ziddy Autowerks
