Results 1 to 9 of 9
Thread: 17 SQ5 oil leak
    Apr 14 2022
    North MS
    17 SQ5 oil leak
    Hey guys,
    New member here. Been reading here for a while, but wanted to post about a problem I'm having. About 2 weeks ago we purchased a 17 SQ5 with 55K miles, from carmax. Had it for a 24hr test drive, all was well. When we brought the car home during our test drive I smelled oil burning, and when I opened the hood it was smoking pretty good. Now they had just detailed the vehicle, so I assumed they got some detailing oil/whatever they use on the egine.manifold/cats, and that was burning off.
    Anyway, we've had it for about 2 weeks now, and when my wife parks it in the garage I can still smell an oil burn. No visible smoke with flash light though. It's left some pretty good marks on the garage floor, and the bottom of the car is coated in oil. Mainly drivers side, but passenger side too. I haven't had time to get under the car yet to drop the cover and see where it could be coming from, but it's leaking pretty good, definitely more than a drop or two.
    Any known areas that leak this significantly? I do have VCDS but haven't done a scan yet, planning on doing that tomorrow. We do have a 90 day warranty from Carmax and I plan on having them fix it, but I'd like to diagnose the issue first before someone tries to blow smoke you know where.
    thanks for the help!
    Junior Member One Ring R-o-n's Avatar
    Jul 13 2018
    Ripon/CA
    vinny7 - could it be that when Carmax did the oil change/service, they forgot to include the sealing o-rings for the oil filter housing?
    Apr 14 2022
    North MS
    That is certainly a possibility. I don’t know if they changed the oil or not. If they did, they didn’t tell us. If that were the case, would it be leaking from the oil filter cap?
    Veteran Member Four Rings EvoToSQ5's Avatar
    Aug 09 2018
    2017 Audi SQ5
    Leominster, MA
    Yes, take a look to see if there’s any oil leaking from the base of the housing where it threads onto the engine. There are 2 o rings that need to be replaced on the housing. One goes around the base attached to the engine just above the threaded portion, the other is inside the actual oil filter housing.
    Mar 07 2020
    Minnesota
    You can visually check the oil filter area for leaks.
    Bring it back to them and let them deal with it. You don't want them to blame you for something, like a cross-threaded oil pan bolt.
    You describe so much oil under there that any attempt to find the source will require cleaning it up. Let them do the work of cleaning all that up.
    There's a 'diaper' on the engine tray that absorbs a lot of oil before it leaks on the floor. That is likely saturated. They should replace that too.
    They might have re-used the oil pan bolt, which has been known to cause leaks.
    Apr 14 2022
    North MS
    Quote Originally Posted by Norskie View Post
    Yes sir you had it correct. Took it in today, got a call a little while later that it was leaking from the oil drain plug. So they changed the oil, and replaced the bolt. He said he was trying to clean the engine tray with a degreaser, but if that didn't work he was going to order a new one. He called me back and said all work is done, replaced the battery as well, and he ordered a new engine tray.
    thanks for the help guys
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by vinny7 View Post
    Glad they found and fixed the leak. As stated above, the tray has a big "diaper" absorbent pad. It can hold a lot of oil, maybe several quarts! Its going to be hard for them to get all the oil out.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Ask them if they changed the crush collar with the drain bolt. Its a change every time item. Chances are that they did not change it before which is why it was leaking . . . and will probably leak again if they did not replace the crush collar.
    If you decide to do your own oil maintenance get an extractor so you can suck the oil out through the dipstick tube. Oil filter is up top as well so then you have no reason to lift the vehicle and drop the belly pan to change oil.
    Junior Member Two Rings schism75's Avatar
    Aug 13 2022
    16' SQ5 & 19' KTM SUPERDUKE 1290 R
    WMASS
    I just picked up a used 16' Sq5 with an oil drain bolt leak. I am not going to lie, I was sweating a bit while waiting for my oil change kit from FCP Euro. I was thinking stripped pan but thankfully, it was the original drain plug bolt and the new 6mm with copper washer from my kit sealed up nicely.
