Results 1 to 4 of 4
    Junior Member One Ring
    Mar 07 2022
    Martinsburg WV
    ARP Head bolt torque specs
    Alright guys, just bought an a4 1.8t with a cracked head. I am in the process of replacing the head and turbo because my original has decent shaft play. My question is what is the torque specs for the ARP head bolts? I know that the factory ones are torque to yield and I do not know if you use the same specs on ARP bolts or not. Thanks in advance
    Jan 24 2010
    Paramus,NJ USA
    Different spec for ARP bolts. Are you using them in a 06A block?? 10mm bolts or 11mm?? If your rocking the stock 10mm stud kit. You have stud kit with nuts or bolts?? If you have 10mm stud kit use these instructions:
    https://arpinstructions.com/instructions/204-4103.pdf
    Ziddy Autowerks
    Mar 07 2022
    Martinsburg WV
    I am pretty sure it is the 06A block, the crack head coming off of the car is the AMB head. The bolts that I am using I believe are 10mm, I am getting them from ecs ARP p/n204-3901. I am not using the stud kit
    Mar 07 2022
    Martinsburg WV
    I have answered my own question, thank you for your help. I will leave this link in case anyone else looks for it https://tech.arp-bolts.com/instructions/204-3901.pdf
