To summarize, this new mechanic I used eventually fixed my coolant leak after an incomplete job the first time. He replaced the water pump, thermostat, and a pipe. Afterwards, my check engine light turned on, and he told me it would turn off after driving 1,000 miles. After 1,000 miles, it was still on. He then said my car is generating codes P2005 and P2006 which according to him means "the intake manifold needs to be replaced". However, P2005 actually means "stuck open" and P2006 means "stuck closed" which seem contradictory to me. Other threads on Audizine have shown that incorrectly reassembling the engine can lead to the intake manifold getting stuck. The mechanic reopened the car and showed me my intake manifold flaps are stuck.
Is it possible it was the mechanic's fault? Is there a way to loosen them again, and how do I explain to him what the correct assembly procedure is (e.g. vacuum the flaps while assembling). I didn't have this issue prior to getting my coolant leak repaired.
Full story:
- Mid last year, my 2011 Audi S4 had a coolant leak. I don't recall seeing a check engine light, but received a "turn off engine and check coolant level" warning if the coolant level dropped way below the "MIN" level. Each time I would fill it to the MAX line with distilled water, it would go back down below MIN within a few days.
- Out of convenience, I took the car to a different mechanic than I'm used to. He was recommended by my relative because while he has poor communication skills, his previous work to keep my relative's 2001 Mercedes alive was acceptable, and his prices seemed on the lower end.
- The mechanic replaced the water pump and thermostat. Full invoice is here for reference. Very soon after we received the car back, the check engine light turned on. I had never seen that light come on before. I gave him back the car to inspect it, and a few days later he said everything is fine, and after driving around for me, the light had cleared.
- As I drove my car home, and within two minutes of driving, the check engine light turned on, and two minutes later the "turn off engine and check coolant level" red message popped up! I looked under my car, and sure enough I could see coolant dripping underneath the car. I gave him back my car, and he diagnosed it and realized there was a pipe near the water pump that he missed, and that needs replacing, too.
- He replaced the water pipe, and the coolant leak was gone. BUT, the check engine light remained.
- He told me that the check engine light should disappear automatically after driving 1,000 miles. I drove 1,000 miles, light was still on.
- Then he plugged into my car to check the error codes, and identified that the engine codes being generated were P2005 and P2006, which according to him meant "the intake manifold needs replacing." I did some research, and P2005 means "intake manifold is stuck open", and P2006 means "intake manifold is stuck closed." Those seem contradictory.
- Looking at other threads here on Audizine, it seems that incorrectly re-assembling the engine can result in the Intake Manifold getting stuck:
Example 1: Intake manifold stuck after incorrect reassembly after thermostat/waterpump replacement
Example 2: Intake manifold flaps stuck closed because the lips got pushed to the wrong side during reassembly
Quote:What happened was when I removed the supercharger, I had started removing the fuel rail assembly to clean the valves. When doing so, without applying vacuum to the flap actuator the flaps popped up over the lip when they should be on the other side. I will post photos with my phone so you can see what I'm talking about here to help anyone in the future if this happens to them after removal of the supercharger.
- So, I told him that I think the intake manifold might have been jammed during reassembly of the car. My relative takes the car to him, the mechanic opens the car and these pics and videos were taken:
- The mechanic says that the 3 long screws besides each intake manifold ensure that the engine is aligned properly when putting it back together, and there's no way he could have installed it in a way that would cause the intake manifolds to be stuck. Then, they took a picture and a video showing that all 6 of the intake manifold flaps are jammed....
Picture the mechanic sent me of the intake manifold: click here in case image isn't showing above directly embedded in the post
Video the mechanic sent me of the intake manifold: https://www.dropbox.com/s/88quyyk8rh...stuck.mov?dl=0
To me this seems incredibly unbelievable that I didn't have this issue before and after the repair, I have a car with a check engine light and spontaneously an intake manifold issue. I brought up another thread I read where it mentions vacuum pressure should be applied to ensure the intake manifold flaps are in the correct orientation during installation...but he goes back to the video where he shows the flaps are stuck. So now he wants to charge me to replace both left and right intake manifolds...
Do you think this really is a coincidence and the wear and tear is there, or is there some sort of instruction I can give this mechanic as to the proper way to keep the intake manifold flaps loose and to re-assemble the car in a way that they don't get jammed?
Sorry for the long post...but if you're still reading this, all I can say is thank you!!! Any advice is appreciated!
