Results 1 to 11 of 11
    Junior Member Two Rings
    Apr 12 2011
    Montreal
    Oled Tail Light Retrofit on Q5 SportBack 2022
    hello everyone,
    I was able to retrofit the Oled tailight on my Q5 2022 Sportback, basic functions are working without the need of parametrization.
    However, VCP just released the dataset, i will try it next week. I have added the coding below each picture.
    i also uploaded a video comparing both tail lights (oled vs led)
    NB: To retrofit EURO oled it requires 2 additional wires to the bcm 46 and also parameterization via VCP
    you need to change the connectors to 8W0 971 636 D for US specs & 8W0 970 636 B for Euro specs
    To activate [46] -> Byte 36 -> Bit 4 : 1 & Bit 5: 1
    To activate [46] -> Byte 36 -> Bit 4 : 0 & Bit 5: 1
    To activate [46] -> Byte 36 -> Bit 4 : 1 & Bit 5: 0
    EURO OLED Retrofit video
    Here are the wiring diagrams for retrofitting the EURO Oled/LED, i have circled the additional wire that needs to be added to separate the turn signal / brake light.. Thats only needed if Euro lights are installed in a US specs car
    Mar 13 2018
    Sweet, great job…
    Stage 2 Banner Advertiser Four Rings Miranda@Nemesis's Avatar
    Apr 15 2020
    24' Q5e & '18 TTRS
    Nueva York
    SWEET!!! thank you. Been waiting for someone to do this.
    Did you source the OLED’s at your local dealer? Or overseas? Are they essentially the same thing with the addition of the 2 wires and different connector?
    [email protected]
    Nemesis Flickr | C43 Build | IG
    Apr 12 2011
    Montreal
    Quote Originally Posted by Miranda@Nemesis View Post
    They are essentially the same thing except for the connectors. The 2 wires are only needed if you want to put Euro tail lights, but it will also require to upload a dataset using vcp.
    However, the swap is straight forward for US Led to US Oled or Euro Led to Euro Oled without the need of dataset.
    On the downside, when i change the mode in audi drive select the tail lights dont change, and the proximity approach doesnt work yet, (havent figured out the coding)
    But the good thing, the animations work for coming/leaving home :)
    Sep 19 2006
    Boston
    When changing drive select modes how do the tail lights change? Same as SQ5 tails? Odd question, but do these fit previous 2018 models? Such a cool change
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Awesome. I was wondering if this was possible for a '21, looks like it would be the same.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Apr 12 2011
    Montreal
    Quote Originally Posted by jlaudio View Post
    Yes it can be done on 2021/2022 & now 2023.
    Quote Originally Posted by Nexus1155 View Post
    i haven't figured out how to change it using the drive select however, by activating Byte 36 => Bit 4, Bit 5, Bit, 6 & Bit 7 the dynamic signature will be on, as shown on the video
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    Why wouldn’t it be? The Prestige trims had the OLED tail lights for ‘21.
    iain
    Apr 12 2011
    Montreal
    If anyone wants to convert/retrofit their tail-lights to OLED US or Euro Specs. Contact me via DM. I have a set of US & a set of Euro for sale
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by kdagher View Post
    DM
    I thought there might be hardware differences other than the light bodies themselves.
    '21 SQ5
    Apr 12 2011
    Montreal
    DM
    Replied
