I've been looking at the oil screen extensively for quite some time, and had a light bulb moment the other night.
The facts:
The original oil screen that fed the turbochargers had a very fine mesh in it. This mesh filtered down to a micron level that was finer than what the factory oil filter would remove from the oiling system.
The oil lines run vertically out of the valley next to the exhaust manifolds, and next to the turbine housings of the turbochargers.
The oil lines do not have heatshields on them.
The oil lines are fed directly from the oil galley that feeds the cylinder heads, and numerous other solenoids/sensors.
There is a screen in each cylinder head that filters the oil post oil filter as it feeds into the cylinder head.
There is a check valve below the oil screen that feeds the turbochargers to prevent drain back from the oil lines into the cylinder heads.
The software was revised by Audi, and was pushed from the dealerships to add a longer post engine shutdown fan runtime about the same time the revised more porous oil screen was released.
Journal bearing turbochargers have operated on countless other vehicles from the dawn of turbocharger journal bearing technology inception without an oil screen, without damage to the journal bearings of the turbos in some cases millions of miles on diesel trucks without rebuilds with oil that is significantly dirtier than even a neglected 4.0t would be without issue.
The hypothesis based on these facts:
The fine mesh oil screen was not installed to protect the turbos, and the screen clogging resulted from coked oil particles collecting on the screen during oil drain back post engine shutdown. This problem being exacerbated by poor oil maintenance, or incorrect oils used by owners.
There is a screen installed pre cylinder head that is designed to protect the cam bearings, lifters, and cylinder on demand system from contamination.
Think about it.
You shut the engine down after a hard run. You have oil in very thin lines, without a heatshield sitting next to hot exhaust manifolds, and a hot turbine housing on engine shutdown.
Non-synthetic oil can begin to break down at 300F, and cause "coking" carbon buildup, and leave carbon deposits.
You shut the engine down, oil pressure goes to zero, the check valve shuts. The oil begins to sit stagnant in the unheatshielded oil lines in the valley next to these hot components. The oil cannot drain back at a significant rate. The oil begins to cook in the lines.
While the check valve is closed, there will still be a small amount oil that sneaks past, and that oil will continue to drain into the valley the longer the engine is shut down.
The coked oil begins to drain back as well. Without a screen installed directly above the check valve, the particles resulting from coking begin to collect around the check valve, potentially causing it to stick open.
The particles from the coked oil begin to collect in the oil galley that feeds the lifters, the cylinder on demand equipment, and numerous other solenoids\sensors.
I believe that the screen was installed to prevent drain back from the turbochargers, post engine shutdown, from allowing coked oil particles to collect in the oil galley that feeds the turbochargers and all of the top end oil consumers. That's why it was originally a very fine screen with the ability to filter a micron level that was tighter that the OEM filter.
A journal bearing turbo can happily eat quite a big of dirt of significant size prior to it causing damage. The bearing tollerances are fairly loose by comparison to the equipment below the turbochargers. There is a lot of sensitive equipment below the turbo feedline that does not need the introduction of coked oil particles from collecting in them
I believe the extended fan runtime was added to minimize the potential effects of coked oil from collecting against the screen on engine shutdown.
I have only seen significantly clogged screens on cars that ran low quality oil, or were not diligent about their oil changes.
My takeaway.
1) I would run the G revision screen, or no screen at all if you're committed to running high quality oil with religious on time changes.
2) Allow the car to cool down for a bit with a little easy driving prior to shut down.
3) Change your oil religiously
You should avoid the turbocharger oil starvation problem from a clogged screen in its entirety if you follow the three listed steps above.
