So in response to my own old thread, I now know my radiator fan speed controller is bad. Fan stays on all the time regardless of what coolant temp is reported. Okay. Given how you have to pull the front of the car off to get enough room, then hardwire in a new module, which is $$$, at very least I would want to make it removable using Weatherpacks or something so next time won't be as bad. But even easier than that, why can't I just splice a switch into the module's ground wire and manually turn on the fans whenever I drive the car? I've got cars with manual fuel pumps, manual fans, etc, so I'm not worried about forgetting or something, but I am worried about this module failing in some other way and suddenly the fans don't work at all. So secondary question I guess, why can't I just remove the module and wire up a manual fan switch? Or a more modern standalone fan speed controller?
Edit: Forgot to mention, I'm definitely being lazy but that's not the only reason. I'm also worried this part will one day be NLA as I've already seen evidence of its price going way up in recent years, supply going way down, and I have other vintage Audis where critical components are NLA.
