Good evening, I am wondering if someone can tell me what this ticking noise might be that is coming from my engine bay. The ticking noise started about a week ago and I brought my car into the dealer about a month before the ticking happened for a completely different reason. On cold start I hear rattling for about 1-2 seconds and then it goes away. There is a TSB from Audi for new tensioners that should fix the problem but the TSB states the noise itself doesn't cause harm to the engine. On the other hand, Audi tells me that the timing chain should be fixed soon or it will cause problems down the road. I am wondering if the loose tensioner is causing the ticking noise or if this is an entirely different problem. At first I thought the noise was a lifter that was stuck, but my mechanic told me that he thinks that it might be a VVT Solenoid that is going bad. Took it to the dealer and they put some BG110 oil in it to see if that will fix the noise if it happens to be a lifter. I've driven the car about 20 miles since the BG110 was added and I am still hearing the ticking. The service manager there said that whoever had the car before me had a methanol kit on the car and thinks that my 5th cylinder might be going out. He said that he wanted to perform a compression test to rule that out. I'd hate to throw a bunch of money at the car and not fix it, so was trying to get an idea from the someone in the community who has had experience with this. Below, I have attached the video of the sound. I've started to the hear sound every time I drive the car now, but sometimes its quiet and other times it's loud. I have driven the car for about 500 miles since the ticking noise and I've made it to my destination every time. I am just afraid that it is a matter of time before the car decides to give out on me and break other components costing me more money. Thank you in advance for any help.
https://photos.app.goo.gl/forBa7igcpH5GT12A
Or
