Results 1 to 6 of 6
    Senior Member Three Rings Rerb's Avatar
    Sep 08 2021
    2016 Honda CR-V, 1999 Suzuki Bandit 1200 Turbo
    Maine
    Some torque specs for you fellow torque nerds
    I'm bored at work so here's a little list of torque specs for the b6 s4 thorugh the shops computer:
    STEERING SYSTEM:
    Tie rod jamb nut: 40nm
    Steering rack mounting bolt: 40nm + 90 degrees
    Steering shaft bolt: 22nm
    Banjo bolts: 50nm
    PS pump mounting bolts: 25nm
    Pressure hose bracket: 96nm
    PS pump return hose to pump: 50nm
    PS pressure line to pump: 40nm
    FRONT SUSPENSION(TORQUE AT RIDE HEIGHT):
    Upper ball joint to knuckle: 40nm
    Lower ball joint to knuckle: 110nm
    Upper control arm bushing: 50nm + 90 deg
    Lower control arm to bushing: 70nm + 180 deg
    Upper strut mount: 75nm
    Lower strut mount: 90nm
    Strut center shaft: 50nm
    Anti-roll bar to bracket: 25nm
    Anti-roll bar to control arm: 40nm + 90 deg
    Spindle nut: 200nm + 180deg
    REAR SUSPENSION(TORQUE AT RIDE HEIGHT):
    Upper strut mount: 36nm
    Lower strut mount: 150nm + 90deg
    Lower control arm to strut: 70nm + 90 deg
    Strut adapter to shock: 70nm + 90 deg
    Strut adapter to wheel housing: 55nm
    Upper control arm to strut: 50nm + 90deg
    DRAIN PLUGS:
    Oil drain: 50nm
    Manual trans drain: 23nm
    (doesn't show fill specs)
    LUG NUTS: 115nm
    EXHAUST MANIFOLD: 30nm
    INTAKE MANIFOLD: 10nm
    OIL FILTER: 25nm
    DRIVESHAFT/DRIVELINE:
    Carrier bearing: 23nm
    Driveshaft to trans: 55nm
    Driveshaft to final drive: 55nm
    Driveshaft heatshield: 25nm
    BELT TENSIONER:
    Hex bolt: 70nm
    Tensioner bolt: 20nm
    REAR BRAKES:
    Carrier bolts: 70nm
    Caliper bolts: 75nm
    FRONT BRAKES:
    Caliper to carrier: 110nm
    Carrier bolts: 160nm
    Tension strut bolts: 30nm
    A/C COMPRESSOR: 43nm
    TIMING CONPONENTS AND GUIDES:
    T30 bolts: 10nm
    Head tensioners: 5nm + 90 degrees (8nm)
    Left idler gear: 5mm + 90 degrees
    Right idler gear: 42 nm
    CAM BOLTS:
    from back of engine, going left to right, bolt tightening sequence is 1, 2, 3, 4. torque in the 3 steps below.
    40nm then 100nm then 90 degrees
    MECHANICAL ADJUSTERS: 5 star pattern, 12nm
    TIMING COVER(S) BOLTS:
    t30: 15 nm
    Allen key: 25 nm
    MOTOR/TRANS MOUNTS:
    To block: 42nm
    To bracket 23nm
    Trans mount to subframe: 25 nm
    This is all they really had, might come in handy to have down somewhere to avoid those greasy-handed google searches in the middle of a project, or if you're like me and have snapped too many bolts to trust what "tight" is.
    Nov 12 2015
    Oregon
    Nice work man!
    Sent from my SM-N960U1 using Tapatalk
    My build log
    Veteran Member Four Rings Rol-co's Avatar
    Dec 12 2020
    Europe (NL)
    Nice one, i almost never use them but m8 come in handy.
    Saved!
    Only milk and juice come in two liters, "05 S4 B7 tipt Avant phantomschwarz/schwarz
    Jan 10 2020
    2005 Audi B6 S4 Cabrio; 99 Ford Ranger
    Herndon VA
    Thanks for this! Very helpful!!!
    Junior Member One Ring
    Mar 07 2019
    MN
    That's awesome, thanks!
    Mar 30 2024
    Mania, Philippines
    Thank You for finding the time while in the office...Yes I get off on these matters..."You know if not, then - what for / might as well not". Don't forget to calibrate the wrenches... Thank you again
