Results 1 to 12 of 12
    Mar 29 2019
    Audi S8, Audi Q7
    Atlanta/GA
    Lightbulb Aha! Found the difference between the S8 engine vs the plus
    **update...I'm an idiot and didn't realize the standard S8 = RS7 (not s7) and the S8 Plus = RS7 Performance. So the below info maybe moot**
    It’s actually pretty substantial imho:
    Different valves
    Different cams
    Additional water cooler
    Larger intake piping
    Turbos (duh)
    Etc
    https://youtu.be/ra7zTXv1DfU
    Since I am on the hunt for a S8, this swayed me to focus on the Plus
    Now: D4 Audi S8, BBS CHR, RocEuro Intakes, DS1, mr12volt carplay retrofit, muffler delete
    Gone: Mk7.5 Golf R : IE Stage 1 Tune, 18x9 Enkei RPF1, H&R Spacers, 034 Motorsports TIP and Intake Hose, Mountune DSG Paddles, Autokey LED front and rear footwell lights
    Gone: 2019 Audi S4: APR 93 Tune, AWE FMIC, Eventuri Intake, 034 Motorsport springs, BBS CHR Wheels, Muffler Delete, ECS Tranny Mount, RS4 Paddles and some other stuff I forgot about.
    Dec 05 2020
    Newark
    Isn't that rs7 vs s7? S8 and s8+ have the same intake.
    Mar 29 2019
    Audi S8, Audi Q7
    Atlanta/GA
    Quote Originally Posted by 16AudiS8+ View Post
    well yes and you correct on the intake but I was running on the impression that the S8 plus is running the rs7 engine (more or less) and the S8 was more akin to the s7.
    Dec 05 2020
    Newark
    No a8/s6/s7 all have the higher compression motor. All s8s and rs7 get a lower compression one. S8 have rs7 sized turbo but cast wheel, where the s8+ gets the rs7 billet wheel.
    Not sure if there are differences more than that. You might want to see if the rs7 vs rs7 performance are any different. Since the s8+ and rs7 performance had same stock hp I think they might have same engine.
    Mar 29 2019
    Audi S8, Audi Q7
    Atlanta/GA
    ahhhh....okay that makes sense
    Junior Member Two Rings
    May 04 2022
    PA
    16AudiS8+,
    Do you happen to have a reference for that?
    First I've heard that and just pondering out loud; 'Why would they make a cast wheel of a unique size for just the S8, which probably had the lowest production numbers of the related models?'
    It is very plausible that the RS7 Performance and S8+ were PURELY software tuning changes... Whenever I see mention of actual hardware difference I take note, but I haven't seen any confirmed.
    Cheers
    Dec 05 2020
    Newark
    Quote Originally Posted by MEnginerdS8 View Post
    16AudiS8+,
    Cheers
    Do you have an s8 that's not a plus? I can give you the part numbers from my plus turbos directly on the turbo and you can compare. When you look them up you'll see mine match with rs7 and the non-plus is specific to the s8. I agree it's odd the s8 had different from beginning.
    May 04 2022
    PA
    Yes I do, 2015. I looked up the parts on parts.audiusa, and they all show the same PN now superseding a slew of PN’s. Even if there are some different parts revs out there over time, not sure how we are going to track that to them having the high capacity wheel that was cast versus billet… could have been some other fairly trivial change that drove the part number revision.
    '15 D4 S8 - DS1, bTres, TS1's, TS WG, Stock Airboxes w/BMC's mated to SRM Intakes, custom active 3" dual exhaust, HPFPs/lines/etc, RacingBrakes Rotors, 21" OZ Leggera HLT w/PilotSport4s, VCDS Lowered; Daytona Grey / Vermont Brown w/B&O, CF Spoiler + Pillars
    '05 W220 S55 AMG Tuned w/Pully, '06 B7 A4, '10 GMT900 ESV, '94 Fbody, plus some 2 wheel and no-wheel stuff... Former: '87 TType, 83' CJ7, '06 LJ
    Dec 05 2020
    Newark
    So mine are 079145703r and 079145704r. Did you see those numbers in your supersessions at all?
    When u search on parts.audiusa shows fitment for 2014-2018 rs7, 2016-2018 rs7 performance and only 2016-2018 s8+.
    May 04 2022
    PA
    Mine are the same part number rev O vs R.
    The part system is not perfect and it still doesn’t tell us what the actual difference is. No I don’t see Directly on the web page that revR superseeded revO, but that’s usually how it goes. IF They really would be different materials in the same geometry they will make the same power up till the moment that mine flies apart … lol
    Dec 05 2020
    Newark
    Do you happen to have a picture if your wheels? Apparently can see picture and tell difference between a cast wheel and billet wheel.
    Veteran Member Four Rings a4000's Avatar
    Nov 30 2004
    Pittsburgh
    S8+, they're billet
    '17 Audi S8 plus // DS1 // E40 // SRM TCU // SRM Flex // SRM Manifolds // SRM 3" Intakes // 034 HPFP // ARM Downpipes // Milltek Non-Res // Ibis // Black with Arras Red Stitching // Dynamic Package // Bang & Olufsen // Black Optics // Driver Assistance // Cold Weather // CETE ASC // 21x9 Ferrada FR8 // PS4S
    '19 Q7 3.0T Prestige // Audi Design Selection Murillo Brown // Luxury // B&O // Black Optics // Adaptive Chassis // Cold Weather // Tow // Night Vision
