Results 1 to 7 of 7
    Mar 31 2022
    Australia
    Lower Control Arm confusion!
    Hey all, not sure if this question has been asked before, but I have an Audi Q5 that was manufactured in July 2010, I'm planning on replacing the lower front control arms on both sides as one of the bushings has decided to completely crack and fail. I'm having a little bit of trouble with part numbers and brands to buy. From the research that I've done and taking a look at the ball joints, I believe I have the refreshed m14 ball joints as opposed to the m12 ones. Could someone help me with a sanity check and verify that what I've said is correct. Also, between TRW, Lemforder, Meyle HD and 034 Density Line, what's the best option to go with?
    Here's what I've kind of gathered so far for Lemforder:
    3896701 - lemforder right lower front rearward
    3896601 - lemforder left lower front rearward
    3748601 - lemforder left lower front forward (m14?)
    3748701 - lemforder right lower front forward (m14?)
    4292201 - lemforder ball joint (m14?)
    3619201 - lemforder left lower front forward (m12?)
    3619301 - lemforder right lower front forward (m12?)
    3689901 - lemforder ball joint (m12?)
    Dec 01 2020
    2014 Q5 2.0T
    Why are you wasting your time with this nonsense? Just buy the parts you need based on your VIN and buy once, cry once.......
    Jul 31 2016
    PA
    Quote Originally Posted by ShiiGemi View Post
    I would just by the 034 kits or the Meyle kits, they should have everything you need including any hardware. Use FCP for the lifetime warranty.
    Sent from my Pixel 6 Pro using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Registered User Two Rings
    Sep 01 2021
    Branford / CT
    Hello. I am Keven, a retail sales rep at XLR8. I want to help you find the correct part. We stock thousands of parts from many different manufacturers like APR, 034, AWE, Milltek, Scorpion, and many more. We have the DENSITY LINE LOWER CONTROL ARM KIT in stock, B8/B8.5 AUDI Q5/SQ5. Like you said that your Audi Q5 was manufactured in July 2010, you would need the Late version (M14). How the early version is for car build dates up to Nov 2, 2009, & Late M14 - Build Dates from Nov 3, 2009. We offer free shipping to the cont 48 US. No tax. also, if there are any questions, feel free to DM Me or send an email over at [email protected] or call in at 203-483-6100 ex 1002
    https://xlr8performance.com/i-266-03...tm_medium=XLR8
    Established Member Two Rings tytus1994's Avatar
    Mar 25 2020
    Bradenton, FL
    Quote Originally Posted by djn876 View Post
    Question I have been trying to find the full upper and lower meyle HD kit on fcp but they only list the uppers for the sq5. Are the q5s the same?
    Sent from my SM-N975U using Tapatalk
    2016 SQ5 Sepang Blue
    034 stage 1 ECU/TCU
    Nov 23 2021
    Utah
    I’d assume so, they should in theory be the same mechanism
    Mar 25 2020
    Bradenton, FL
    Quote Originally Posted by Slow_Q5 View Post
    On fcp euro they list the lowers for q5 but not sq5
    034 stage 1 ECU/TCU
