I think a better question is: What are things that are great about the B5?
- Body is quite rust resistant compared to almost anything else of the era.
- Almost no problems with the bottom end (block, pistons, rings) at stock power on any of the available engines (in North America, anyway). Even if you starve it for oil, you might kill the cylinder head, but the bottom end is almost always fine.
- Solid on-road feel with basically zero torque steer thanks to "virtual steering axis" front end and longitudinal drivetrain orientation. This is what makes MacPherson cars feel lesser in comparison.
- Obviously quattro is amazing. It hits all 4 wheels at once with basically equal torque - a huge advantage over "reactive" systems that require the front wheels to slip first.
- The AWD being "all mechanical" means it doesn't break. You can't blow a fuse and be back in Front Wheel Drive. The AWD always hits. Every time. If the car moves, the AWD is working.
- The center diff is all gears. There is no clutch pack or viscous unit that will wear out. Most other 25 year old AWD systems have a wear item that reduces their effectiveness over time. Not quattro. Traction will basically be like new...forever.
- Not overly computerized. When you turn the key, your hand closes a switch that energizes the actual starter motor. Imagine that. The headlight switch closes contacts that send power to...the headlights. It's Crazy!
- There is no immobilizer that will lock you out of operating your own car because of some RF chip nonsense.
- The roof gutters don't randomly rust out (looking at you, B6 chassis).
