OIL CONSUMPTION
Part Number | Part Name | Quantity |
06H-107-065-DM | Engine Piston | 4 |
D-174-003-M2 | Upper Oil Pan Sealer | 1 |
D-154-103-A1 | Valve Cover Sealer | 1 |
N-013-814-9 | Hose & Tube Assembly O-Ring | 2 |
N-013-851-4 | Oil Inlet Tube O-Ring | 2 |
N-101-562-06 | Mount Bracket Bolt | 4 |
N-105-540-05 | Valve Cover Bolt | 22 |
N-906-650-01 | Clutch Flywheel Bolt | 8 |
N-910-488-02 | Upper Oil Pan Bolt | 11 |
N-910-506-01 | Upper Oil Pan Bolt | 2 |
N-910-967-01 | Mirror Housing Mount Bolt | 21 |
N-911-432-03 | Clutch Flywheel Bolt | 3 |
N-911-489-01 | Motor Mount Mount Bolt | 2 |
wht001319 | Engine Connecting Rod Bolt | 8 |
06D-103-385-D | Engine Cylinder Head Bolt | 10 |
06H-103-121-J | Engine Timing Cover | 1 |
06F-145-757-L | Oil Outlet Tube Gasket | 1 |
N-105-724-03 | Cover Plate Bolt | 1 |
8K0-253-115-L | Gasket | 1 |
06K-103-171-P | Engine Crankshaft Seal | 1 |
06H-103-383-AF | Head Gasket | 1 |
N-102-018-01 | Power Brake Booster Vacuum Hose Clamp | 1 |
06H-103-483-C | Front Cover Gasket | 1 |
06J-115-403-Q | Oil Filter | 1 |
06H-103-138-E | Engine Oil Pan Baffle | 1 |
06B-103-113-C | Engine Camshaft Plug | 1 |
N-911-297-01 | Screw | 2 |
N-911-295-01 | Screw | 2 |
N-911-296-01 | Starter Mount Bolt | 2 |
N-911-292-01 | Screw | 2 |
N-911-507-01 | Screw | 1 |
N-911-294-01 | Screw | 1 |
N-910-967-02 | Clutch Release Shaft Lever Bolt | 3 |
06H-115-418-AA | Timing Case Plug | 1 |
wht003463 | Tube O-Ring | 1 |
WHT-007-212-B | Camshaft Seal | 1 |
N-905-583-01 | Circlip | 4 |
WHT-002-514 | Catalytic Converter Lock Nut | 4 |
There are several jobs that are much easier at the same time and therefore recommended to strongly consider...
TIMING CHAINS, GUIDES, AND TENSIONERS
06K-109-158-BP | TIMING CHAIN | 1 |
06K-109-467-K | TENSIONER | 1 |
N-910-967-02 | BOLT | 15 |
06K-109-210-AF | TIMING CASE | 1 |
WHT-009-475 | SCREW | 1 |
06H-103-483-C | GASKET | 1 |
06H-103-483-D | GASKET | 1 |
N-105-724-03 | SCREW | 1 |
WHT-007-212-B | SEAL RING | 1 |
WHT-003-463 | SEAL RING | 1 |
***06J-115-403-Q | OIL FILTER | 1 |
D-176-501-A1A | SEALANT 1/ | 1 |
D-176-501-A1 | SEALANT | 1 |
06K-109-469-N | RAIL | 1 |
06H-109-509-Q | RAIL | 1 |
06K-109-469-M | RAIL | 1 |
06K-109-158-BS | TIMING CHAIN | 1 |
06H-109-469-AQ | RAIL | 1 |
06H-109-509-P | RAIL | 1 |
06H-109-469-AH | RAIL | 1 |
06H-109-467-BA | TENSIONER | 1 |
***06H-103-144-K | CAM BRACKET | 1 |
WATER PUMP
06H-121-026-DR | WATER PUMP KIT | 1 |
***06H-121-605-E | TOOTH BELT | 1 |
06H-121-131-C | UNION | 1 |
OTHER
06J-260-849-F | SERPANTINE | 1 |
*** = May be duplicated in another job list or is optional
