Greetings one and all!
I'm Bkwrzdub (Backwards dub)
...and I'm retarded...
I've been dubbing since I could drive... back when they invented the wheel, fire and dirt.
So, granted, I've had loads of 1.8t's, TDI's, a few VRs, A fox (yee B Series!) an audi 90 (yee more b chassis!) a b6 a4 avant wagon (this is under the knife atm)
Anyways
A few months back, my daily mk7 gti's loan was all paid up and I felt like doing a stupid.
lo and behold a 987.1 Cayman came up local to me on the cheap - naturally, I'm a curious bugger...
"how bad could it possibly be?"
well.........
famous last words
So, fast forward a few weeks with the vehicle
It's fucking FANTASTIC, it handles AMAZING!
but it has bore scoring.
I'm one to keep my cars an unusually long amount of time (I kept my grandparents old diesel TD mk2 on the road up until about 4-5 years ago)
So I'm slowing down my "flipping" and beginning to get to "collecting"
This is one I want to keep
After doing some number crunching, A removal, recondition, and reinstall of a flat6 with bore scoring can be upwards of 25k USD...
that tells me - others whom are faint of heart wouldn't be so daring and would sell the car.
and like I said above, I'm retarded and will try anything once (maybe twice)
but ya dont go driving dubs for 20 years and dont learn nuttin'
So without further adieu, welcome my madness
40v 987.1 Swap!
I've seen the following Examples & Resources
https://sites.google.com/view/boxsterv8swap/home
(I've been in contact with Fincher's Garage - Stand up dude!)
https://www.youtube.com/watch?v=qyDB...bO9Kena81b1GuY
986 Rockster by "home built by jeff"
I was a recent watcher of Youtuber JaseWilks whom had done this on HIS cayman.....
but... I dont see anyone else doing this on cayman 987.1's
to my understanding, the 2.7 is a bit more robust and not afflicted by bore score like the 3.4
It's running, driving and carting my fat ass around quite nicely at the moment, but at some point... it's going to go "big bada boom"
And it WILL go BOOM sooner than later because I've checked my pleats of the oil filter while removed and disassembled and there ARE DEFINATELY
metal pieceS about the size of a popcorn kernel in the oil.
and, since it's a porsche, it comes out the bottom - Naturally.
Anyways
What I have is:
-987.1 Cayman S Gen1 with 3.4 flat 6
-012 g87.20 6spd Gearbox
What I have collected are:
-2004 Audi D3 A8 BFM code 4.2 40v
-Starter & Alternator
-The Associated ME7.1.1 Wiring harness - NO ECU
-Bufkin pipe
-C5 A6 Alternator bracket/Oil cooler
And now..... I know there are many variations of the audi v8.... 32v and 40v, 3.6L to 4.2L, S motors, the intakes, the cams.... and in my case
I've got the 03-05 D3 A8, so that's like the D2 S8 motor? (less cams? different intake runner flaps - double actuation, not single)
and that it's also based off the RS4?(6?) block where the lower bolt holes differ, but not a major issue.
I've also got the Factory Bellhousing Spacer for the BFM engine, but I'm fairly certain I'm NOT to use this?
but could stand to get the earlier 2.7t engine spacer as a template for the upper starter bolt
which needs to be drilled into this block?
(as shown here)
https://www.rs6.com/showthread.php/2...p-Teaser/page2
The crank is an 8 bolt, rather than the 10bolt RS style block
and many have done the manual 4.2L Swap with the TTV Racing Flywheel with Stock B7 RS4 Clutch Disk & Pressure plate
Im not opposed to running the TTV equipment, but I'm wondering if the Clutch Masters unit P/N 02053-TD8S-A
if that's got the proper flywheel (with 8bolt & 60-2 Tooth ring - with proper orientation for Crank angle sensor)
and if it has the proper overall clutch basket height to fit within the bellhousing. (I DONT EXPECT ANYONE TO READILY ANSWER THIS)
most of my questions are based around mounting 012 g87.20 Transmission to BFM 40v 4.2L - The physical bits
I should be able to handle the fabrication, wiring, cooling, etc
but I have literally zero experience on any audi v8's
ironically I live in the middle of big domestic truck country
(I have one for work, so I cant poke fun)
If anyone else happens to know of any other 986box or 987cay 40v swaps going on
post it!
I see more boxster guys trying this than I do see caymans
but I think that using the vw/audi lego like this makes for a quite the interesting alternative
Thanks Gents!
