Results 1 to 38 of 38
    Sep 27 2020
    Golf TDI
    San Diego
    Valve Master Titanium exhaust
    Anyone else try this exhaust?
    https://valvemaster.ca/collections/m...41123700441274
    Has resonators = excellent. Does not work with OEM valves, not sure about that. Is valve actuation still an issue (loss of torque) when tuned?
    The price vs Akra or BoostLogic is much better.
    Nov 11 2021
    Atlanta, GA
    Quote Originally Posted by DrMerl View Post
    I'd be curious about drone, thats usually my deal breaker. Otherwise it looks beautiful.
    Nov 11 2021
    Atlanta, GA
    Video of this on a TTRS:
    https://www.youtube.com/watch?v=28HG...nnel=1Stockf30
    Skip to 29:45
    Senior Member Three Rings 8STTRS's Avatar
    Jul 28 2021
    Navarre, Florida
    It's legit the same kit that's out there from a bunch of other vendors. It's basically the same kit I have on my TT RS. It's lightweight and pretty but, it drones something fierce at times. They will all fiercely claim that their kit is unique and that no one else is selling it, etc., etc. It's the same damn kit. They are ALL made in China. Despite that, I like my exhaust just fine and there were no quality issues that were readily apparent to myself or to the shops that have seen it first hand.
    2018 Audi TT RS
    JDY Next Gen 6670 coming soon (shooting for 975-1kwhp on low boost).
    Veteran Member Three Rings jd_rs3's Avatar
    Dec 18 2018
    Longmont, CO
    Need to see pics of the tip spacing - looks like they are touching the top of the valance opening
    2018 nardo gray rs3 - sold
    Sep 27 2020
    Golf TDI
    San Diego
    The mid pipe resonators don't help much? Drone is no fun if it can be avoided. Same drone with valves open or closed?
    Jul 28 2021
    Navarre, Florida
    Mine did not have an option for a resonator but, I also don't have a conventional mid-pipe, per se. So it wouldn't have been an option for me either way. When the valves are closed and you're driving around like a normal person, it's perfectly fine with very little drone. One thing they don't readily tell you, however, is how the valves work. You can absolutely extend your valve harness to meet up with the valve actuators on this kit, which I intend to do. However, it comes with this box, a dongle, lots of wires and a remote to actuate the valve manually. I would caution you to not trust that remote and to tie it into your factory valve harness. You'll need the actuator and spring from your stock exhaust to make it work. I have only accelerated hard once while the valves were closed and it let out a sound that did not strike me as healthy for the vehicle. I have since opted to keep the valves open all the time except for cold starts. Once my car gets back from RSP, one of the first things I'm going to do is fix that valve situation.
    2018 Audi TT RS
    Jul 28 2021
    Navarre, Florida
    Quote Originally Posted by jd_rs3 View Post
    The tips and the piping at the end can be tilted to give you clearance. That's what I did on mine. I think I opted for about 1/2-3/4" gap from my valance.
    2018 Audi TT RS
    Sep 01 2012
    Edmonton
    I spoke to them a few weeks again prior to release and was going to promo the system. Here's some info... in the end I decided to stick with my Remus setup.
    Sent from my SM-G970W using Audizine Forum mobile app
    2018 RS3 Panther Black
    Jun 01 2007
    NOVA
    lol the quality of the product compared to akra/bl is a clear indicator of why they shouldn't even be compared. this is chinese trash. buy once, cry once.
    Sold // 2018 RS3 - Unitronic TTE700 / BoostLogic / 034 everything / BBS RI-A / etc
    2023 SQ5 - stock + BBS CI-R
    2024 Wrangler 392 - BC Forged LE81 + 37" KO2
    2009 Corvette Z06 - HCI / BC Forged MLE215
    Nov 11 2021
    Atlanta, GA
    Regular resonators dont silence drone.. speaking from experience. You need a Helmholtz resonator or something like the Corsa RSC muffler in there to wipe it out.
    Sep 01 2012
    Edmonton
    Quote Originally Posted by TToysRuS View Post
    Yah, I know when I seen that I bailed.
    Jul 28 2021
    Navarre, Florida
    Quote Originally Posted by cseaman View Post
    While I would agree with you that it should not be in the same conversation as Akrapovic and Boost Logic, it isn't what I would call trash. I've seen some trashy exhaust setups in my time and while this doesn't scream quality, it certainly suffices the point. I am surprised, however, at the quality of the aftermarket exhaust setups for these vehicles in general; barring the aforementioned brands.
    2018 Audi TT RS
    Sep 27 2020
    Golf TDI
    San Diego
    Is there anyone making a titanium exhaust that uses the proper Helmholtz design along with the OEM valve system?
    From feedback here the BL has drone and the Akra is unobtanium now.
    At this point the price isn't the issue, it's just finding a properly designed unit that won't blow your eardrums out. It's the weight savings part that I'm looking for.
    Nov 11 2021
    Atlanta, GA
    I contacted Unobtanium Welding in Canada and they would be willing to prototype one using Corsa RSC universal 3" in/out mufflers and then titanium piping/resonators throughout otherwise, but they need a car locally to build jigs and develop it. Price would be near $6k in titanium. Zero drone, very lightweight, albeit a touch heavier than BL due to the stainless Corsa mufflers. I have a single Corsa 3" RSC muffler on my Escalade 6.2 that has a stock muffler delete and flapper and resonator delete too. It went from unbearable helicopter chop to ZERO drone at all and half the volume, all from the RSC muffler. Pretty incredible, and its straight through.
    https://www.unobtainium.ca/
    If one person got it prototyped, they could make jigs and produce them en masse for us.
    I also spoke with BL about incorporating a drone solution and they are considering it but they have 20+ projects ahead of that idea.
    Dec 18 2018
    Longmont, CO
    Slightly louder sound (not going to say better), 30lbs in weight savings and bragging rights that you have a titanium exhaust for $6,000? What am I missing?
    Sent from my Pixel 4a using Tapatalk
    Sep 27 2020
    Golf TDI
    San Diego
    Nothing too magical about Hemholtz design, titanium pipe is not that much. It'll be the skill of the welder/labor that should be the cost.
    Drone Calculator based on SoS at different temps.
    http://super-null.com/drone.html
    Simple demo, it looks this happens to be a 5cyl Volvo =)
    https://www.youtube.com/watch?v=PQVQi68p-h4
    Would be nice to have someone in the states, or even So Cal (I could offer my TT RS for proto) to consider a build.
    Nov 11 2021
    Atlanta, GA
    Preference for sound, weight savings (minor), looks, etc. A lot of dough. Some people have the bankroll to support it, some dont or choose not to spend that much for what you get. To each their own. Frankly I'd rather have inconel than Ti.
    Dec 18 2018
    Longmont, CO
    Fair point. Thanks. My intention was not to argue - I was sincerely trying to understand the benefits considering the high cost.
    Sep 01 2012
    Edmonton
    https://www.audizine.com/forum/showthread.php?t=951204
    They had one left, I'm not sure on status now. Hit them up.
    Not Ti but very well built and sounds really good in my opinion.
    Remus non-resonated CB along with their Mid pipes.
    I've got them paired up with an ASR exhaust controller and Uni DP. I'm pleased with this set-up and I'm picky on exhaust notes my last Audi I went through 3 systems.
    Sep 27 2020
    Golf TDI
    San Diego
    Mmmmm, inconel. $6K would only pay for the clamps, lol.
    https://youtu.be/RRTzGv6LEl8?t=421
    At some point the car will rot away leaving only inconel bones.
    Sep 27 2020
    Golf TDI
    San Diego
    Quote Originally Posted by WAF View Post
    I hit that one up earlier this month, was ready to buy, but it turned out to be mis-marked boxes from Audi is what I read.
    Sep 01 2012
    Edmonton
    Damn, well looks like they sold it to someone 3/17/2022. Would be a bummer to get that in the mail.
    Nov 11 2021
    Atlanta, GA
    Sold to me, confirmed it was mismarked for the TTRS and RS3 boxes. Same issue Europrice ran into. They are officially gone.
    - - - Updated - - -
    Could you post some videos up of your Remus setup? Does it drone at all? I am looking for something better flowing and a bit louder with good tone, no drone. doesnt need to be Ti or anything
    Sep 01 2012
    Edmonton
    - - - Updated - - -
    Non res has a lil drone.
    Resonated doesn't. I'm out of country right now, I'll post when I get home. In the meantime on my Facebook group another member picked up system. I'll see if I can track it down for you.
    Nov 11 2021
    Atlanta, GA
    Jan 02 2019
    Wellington, FL
    If some of you are TTRS I'd suggest JJT Performance, owner is a ttrs owner and enthusiast for several years, I believe will be making a RS3 model as well. That is the exhaust I am getting in TI. Probably one of the best flowing and largest diameter tubing out there in valved format. Lot of R&D went into it.
    Jan 02 2019
    Wellington, FL
    Just confirmed with JJT that helmholtz design is part of theirs FYI.
    Junior Member One Ring
    Dec 09 2018
    Quote Originally Posted by nothingbutspeed View Post
    Any info on timeline? Also have TT RS and may be interested once more info is available.
    Nov 11 2021
    Atlanta, GA
    Will definitely check them out once some reviews come in confirming no drone.
    Oct 08 2021
    Uxbridge MA
    I picked this one up. The muffler is titanium, resonator section is not
    You’re right, it does sound REALLY good. Even on stock tune. Can’t wait to move more air through the pipes
    Nov 11 2021
    Atlanta, GA
    Quote Originally Posted by b1aZe View Post
    Resonator section is the OEM Audi Sport section, just setup to clamp to the Ti muffler with a ball joint. Nice grab! These are getting rare. Any sound clips? Do you have 2nd cats deleted?
    Sep 01 2012
    Edmonton
    Which one?
    Nov 11 2021
    Atlanta, GA
    Which one?
    Akrapovic titanium
    Junior Member Two Rings
    Jan 19 2021
    Arizona
    Quote Originally Posted by 8STTRS View Post
    You're not kidding... I run the AWE V2 Switch-Path and it's not the finest material for the amount of money they charge. Had it not have come with the purchase of the vehicle, I wouldn't personally spend my money.
    I really like this exhaust system. It's the finest of the finest chinesium but I might give it a shot?
    Dec 18 2018
    Longmont, CO
    Talked to Alibaba store... finest of the finest Chinesium from RES (Racing Exhaust Systems) if you order 10 pieces:
    SUS304 $1008 + shipping ($650/piece)
    Titanium (any of 4 colors to choose from) $1648 + shipping ($650/piece)
    ehh.. :Shrugs:
    Sep 01 2012
    Edmonton
    PRIMO right there boys.
    Jan 02 2019
    Wellington, FL
    Quote Originally Posted by CG05 View Post
    Hey he's saying the final finish should be ready fairly soon, so I'm hoping by end of this month, or early next month for it myself.
    Current Stable - Built head, sleeved motor & clutches 2018 Audi TTRS Syvecs IMS 850, Litepseed Magnesium Wheels, CCB's, JJT Titanium Valved Exhaust, Stern Rear Seat Delete etc.
    Previous - Built Motor Unitronic TTE777 RS3, Stage 2 F10 M5, 16 Stage 2 Golf R, 14 C63 507 (Kleeman Supercharged, FBO), 08 CLK63 - ROW Intake/Eurocharged Tuned, 2005 MkIV VW Jetta GLI Stage2 FBO + Nitrous.
