Results 1 to 11 of 11
    Junior Member Two Rings
    Nov 08 2021
    Illinois
    Engine Oil Consumption
    I now know engine oil consumption is an old and well known issue. Any chance some folks have been down this road and have words of wisdom to share?
    2014 Audi A6 2.0t fsi private party purchased in late 2021 with 135k miles. PCV replaced. 2 BG engine oil treatments. Still consuming 1 quart every 400-600 miles of Castro 0W-40. Would another brand or weight help? Any other treatments to free up piston oil control rings?
    Loving our first Audi just really frustrated with oil consumption and not at all prepared to spend $5-6k to independent shop for a partial rebuild.
    Thank you!
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Most of the 2.0 oil consumption problems were thought to be solved after the 2012 engines but I still hear about some 2014s with consumption problems. You might be able to get help from Audi on but probably not. If you are consuming 1 quart per 400 - 600 miles its time to pull the engine and replace the piston rings. With that mileage you might as well rebuild the engine while you are at it.
    Might be time to top off the oil and trade it in. If the car looks good you will still get a good $$ on trade in and put that $5 - 6K towards a newer car.
    Junior Member Two Rings rey_reysA7's Avatar
    Sep 21 2018
    '84 VW GTi
    CO
    Run some ATS chemical 505crf and 505cro to free the rings. Or AMS oil engine flush.
    Sent from my G8142 using Audizine Forum mobile app
    Current Cars 2012 Audi A7 1984 VW Rabbit GTI
    Sold Cars '78 Rabbit '87 Scirocco '99.5 Jetta 2.0 '00 Jetta VR6
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by Wadeboston View Post
    Thank you!
    If you can change the oils yourself, try Pennzoil 5/40. We’ve got two Audis and the that oil that both make it 5-6k before top-off.
    If that doesn’t help and you don’t want to jump into a rebuild, I’d suggest selling as others have note.
    Veteran Member Three Rings A665's Avatar
    Oct 26 2019
    Mid-Atlantic
    Quote Originally Posted by Valpo A7 View Post
    THIS.
    My wife drove a 2011 A4 2.0T (purchased new) and we went through the Audi oil consumption measurement protocol beginning around 75k (?) miles. Finally had the piston rings replaced under the warranty. That solved the oil consumption issue but then, shortly after, we ran into the PCV issue and, finally, a good amount of unidentifiable oil-leak issues. On the last $800 diagnostic & repair visit with a trusted indy shop, I told my wife that if that did not do the trick, we're getting rid of the car----I just couldn't stomach throwing more $$$ at it. Issues arose again within a week's time. About a month later we took it to Carmax. They offered a very decent number. I couldn't wait to unload the car and walk away with a check.
    2013 Audi A6 3.0T Prestige | S-Line / Sport | Full LED | 034 Stage 1 ECU+TCU | ECS Trans Mount Insert | JHM Driveshaft Carrier Bushing | FormulaOne Pinnacle Tint
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Quote Originally Posted by JWebb_C7_Comp View Post
    Exactly my thought. Try a thicker weight oil first - 5w40 that meets VW spec - see what that changes to consumption. Go from there if engine rebuild or selling is the next order of business
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by MattyMarkey View Post
    I’ve tried a few oils on 2.0 Audis. The Pennzoil lasts the longest l, TBN and wear metals are pretty good. Oil and filter at $50-60 on total. Maybe with the peace of mind before selling..
    Established Member Two Rings joserod92's Avatar
    Jan 31 2019
    Dominican Republic.
    Try Motul 8100 xcess Gen 2.
    C7.5 S7
    Jun 19 2018
    NH
    Quote Originally Posted by joserod92 View Post
    ^ I personally use this and have since day 1 of ownership (5w40) and have never had an issue with oil consumption. I also don't have a 2.0t, which is widely known as having worse, engine internals related issues vs a bad pcv on the 4.0t causing the issue.
    I would try either 5w40 mentioned and see if it helps.
    Jan 31 2019
    Dominican Republic.
    I remember my old 3.0t used to consume 1 quart between oil changes and that was using motul 8100 but gen 1, when I switched to Gen 2 it did not consume a drop.
    C7.5 S7
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    that isn't bad, a lot of German cars say this is normal. My 07 Audi A6 3.2 use to use about 1 qt. between changes and same with my 08 BMW 550i
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
