Hello,
I wanted to upload a post on my experience in going to full e85 and is38 on my Audi A3. I haven't seen a lot of post so I hope this thread helps someone. Car info: 2015 Audi A3 Quattro with 70k miles. I bought a unitronic intercooler, auto tech Hpfp, and OE is38 from FCP euro for the lifetime warranty. I went with EQT OTS ECU and TCU tune. I brought my car into a shop to do the install it took about 2 weeks. They ended up having a fueling issue and it turned out the auto tech Hpfp was defective from factory I had to order another one. Installed it into the car and it drove fine. I then picked it up and started driving home like a spirited drive. Car was absolutely amazing and blew my mind it was disgustingly fast. However, 15 minutes into the drive my car started stuttering / bucking around 105mph. I pulled over and turned the car off, because my shop warned me that I should tow the car if this was to happen. I then ignored their advice turned the car back on and continued driving without going into full throttle. I ended up trying to do another WOT pull and the car bucked violently and I pulled over immediately again. I called my shop and told them about my issue they said that I should not try to do any more pulls and get the car back there ASAP. I drove the 15 minutes to the shop without going past 1/4 throttle and the car was perfect and had no issues. They got in the car and data logged. He came back and said something about the car not getting enough fuel again. Excuse me, I don't really know what he was talking about in specific but the data log said that I was requesting about 180 psi somewhere in the car and I was only getting about 9. Now this is where I am today. The car is at the shop and I must wait til Monday to receive an update. I asked him if he had any guesses as what it may be. He said it could be the LPFP or the intake pump or something. I'm eager to get an update on what went wrong in my car, and get it fixed and back on the road. I hope that whoever is reading this finds some type of value hearing someone else's experience. When I get the email or call on Monday im going to update the thread. If anyone has any insight on what might have happened please let me know. I would also like to add that throughout the entire drive I had no lights on the dash and there was no error codes in the car when he tried to read the codes. Also a bit of maintenance history to rule out some things: Spark plugs are correct heat range however they are a bit old they are RS7 spark plugs, recently replaced PCV valve, coil packs are from APR, recently got a haldex service, and transmission service. Hopes this helps out someone! Also I currently have the STOCK LPFP, stock lines, and no MPI.
