Originally Posted by
brad281
Capture the old codes, then clear them out and try to start it again.
I was getting a bunch of misfire codes/running rough and parked it for a couple weeks until I had time to take it in to get looked at. Went to start the car and the battery had died. Replaced the battery and was still getting the same issues. My mechanic told me to clear the codes before driving it again. It drove fine and never had the misfires again. Battery failures can cause some odd things on these cars.
Sent from my SM-A716V using Tapatalk
Thanks for the tip, I'll definitely try clearing out the codes and starting her up.
Here are the logs. I deleted a bunch of the filler lines to try to keep it small.
Address 01: Engine (------CTGE) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 D HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0001
33 Faults Found:
5456 - Starter Will Not Turn
P3054 00 [036] - Jammed or Electrical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 40
Date: 2021.11.24
Time: 22:34:24
Engine RPM: 0.00 /min
9007 - Fuel Pressure Regulator Valve; Bank 2 (N276)
P129B 00 [036] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:03
19320 - Temperature Sensor for Engine Cover
P194E 00 [032] - Signal too High
10258 - Vehicle Speed Sensor
P0501 00 [036] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2022.01.21
Time: 14:20:02
14197 - Cam Adjustment Actuator B; Cylinder 5
P11B3 00 [096] - Elec. Malf. or Open Circuit
14206 - Cam Adjustment Actuator B; Cylinder 8
P11BE 00 [096] - Elec. Malf. or Open Circuit
14191 - Cam Adjustment Actuator B; Cylinder 3
P11AB 00 [096] - Elec. Malf. or Open Circuit
14245 - Exhaust Cam Adjustment Actuator B; Cylinder 5
P11C8 00 [100] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
14254 - Exhaust Cam Adjustment Actuator B; Cylinder 8
P11CE 00 [100] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
14239 - Exhaust Cam Adjustment Actuator B; Cylinder 3
P11C4 00 [100] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
14236 - Exhaust Cam Adjustment Actuator B; Cylinder 2
P11C2 00 [100] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
14221 - Cam Adjustment Actuator A; Cylinder 5
P11B1 00 [096] - Elec. Malf. or Open Circuit
14230 - Cam Adjustment Actuator A; Cylinder 8
P11BD 00 [100] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
14215 - Cam Adjustment Actuator A; Cylinder 3
P11A9 00 [096] - Elec. Malf. or Open Circuit
14212 - Cam Adjustment Actuator A; Cylinder 2
P11A5 00 [100] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
14269 - Exhaust Cam Adjustment Actuator A; Cylinder 5
P11C7 00 [100] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
14278 - Exhaust Cam Adjustment Actuator A; Cylinder 8
P11CD 00 [100] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
14263 - Exhaust Cam Adjustment Actuator A; Cylinder 3
P11C3 00 [100] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
14260 - Exhaust Cam Adjustment Actuator A; Cylinder 2
P11C1 00 [100] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
9803 - No Communications with Parking Assist Control Module A
U0159 00 [032] - -
4717 - Body Control Module (Central Electric)
U0140 00 [032] - No Communications
4720 - Body Control Module (Central Electric 2)
U0141 00 [032] - No Communications
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
17262 - Terminal 30
U140A 00 [032] - Open Circuit
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
5650 - Low Pressure Fuel Sensor (G410)
P2539 00 [101] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:03
22593 - Fuel Level Sensor Circuit
P0461 00 [096] - Implausible Signal
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.11.24
Time: 05:14:18
Engine RPM: 1150.00 /min
10591 - Cylinder 1
P0301 00 [101] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.11.24
Time: 05:14:18
Engine RPM: 1081.00 /min
10592 - Cylinder 2
P0302 00 [101] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.11.24
Time: 05:14:18
Engine RPM: 1131.00 /min
7648 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
P2432 00 [039] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:03
4130 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0108 00 [036] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
11288 - Manifold Pressure / Boost Sensor 2 (G447)
P0242 00 [036] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.12.02
Time: 21:41:04
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
32 Faults Found:
261632 - Brake Boost Pressure Sensor
C054A 00 [109] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2021.11.24
Time: 23:48:44
438272 - Brake Boost Pressure Sensor
C054A 00 [035] - Implausible Signal
260864 - Brake Boost Pressure Sensor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2022.01.21
Time: 14:20:01
