Howdy y’all,
I’ll be posting up on my build thread about my 034 springs/B8 shock install later today.
In the meantime, I noticed that my headlights were definitely aimed too low after lowering.
I followed the directions found in this thread;
https://www.audizine.com/forum/showt...hts-on-B8-5-A4
I didn’t do any of the manual screw adjustments just the “auto adjust” described in one post in that thread that also had a video of the adjustment in real-time.
On iOS it doesn’t have a check mark but rather a slide that says “slide to start” and then while the headlights are adjusting it has a “slide to stop”
I didn’t touch it as it adjusted and then I got a error message on the dash that said something to the effect of “headlight height control out of adjustment”. At that point I did the “swipe to stop”.
I ran a scan and the central electronics module trips fault 01539 - Headlight not adjusted.
Cleared the code And disconnected the OBD11 and tried turning the car on and off but that error message srill comes up.
How can I fix this?
