Results 1 to 8 of 8
    Mar 22 2022
    Georgia
    Thumbs up Bosch 82mm Throttle Body Wiring Help
    hello, i'm doing TB upgrade on my Audi s4 2010 b8.
    i got wiring info for Bosch TB this is the order
    1- Motor -
    2- Poti -
    3- Poti +
    4- Motor +
    5- Poti 2
    6- Poti 1
    My Oem TB is Simens VDO, it was easy to find Pin Diagram for Bosch, but i cant find pin diagram for Siemns VDO
    any info about pin order for OEM harness ?
    Established Member Two Rings serg72's Avatar
    May 19 2021
    Kharkiv, Ukraine
    Quote Originally Posted by Garwa View Post
    1- Motor -
    2- Poti -
    3- Poti +
    4- Motor +
    5- Poti 2
    6- Poti 1
    For oem TB is Simens VDO
    1- Poti 1
    2- Poti +
    3- Motor -
    4- Poti 2
    5- Motor +
    6- Poti -
    2014 Q5 3.0T S-Line | Glacier Grey |034 Stage 2+ 93 octane tune | CTS Crank Pulley 192mm / APR SC Pulley 57.75 | BG HPT ZF8 Tune | 2 CWA-50 pump / Custom HX + custom reservoir (Divorced Coolant Loop) | K&N filter/mod stock box intake /4" Intake Tube/ TB 84mm | 034 HPFP piston | Long tube headers/custom exhaust 2,5" | tires 265/45/20 |
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Audizine truly does have international fellowship! Hope you're staying safe Serg72!
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    May 19 2021
    Kharkiv, Ukraine
    Quote Originally Posted by LYKUNO View Post
    Yes, I'm safe. I hope that this war will end soon.
    What Bosch TB 82mm number do you use?
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by serg72 View Post
    Glad to hear you're safe. We're seeing horrific footage of the war their on a daily basis and we too long for a peaceful end to the hostilities.
    Meanwhile, my 2011 S4 is completely stock, so it's the OEM TB with the restrictive 70mm throat (some say 73mm).
    Stage 3 Forum Advertiser Two Rings Bill@GAS's Avatar
    Nov 29 2022
    Stage 2+ B8.5 S4, billet hybrid C7 S7, built B4 S2 Coupe, big turbo B8.5 S4, B9 S5 coupe
    Ontario, Canada
    I know that this thread is old, but I wanted to put this info here for anyone who may come across it. You do not need to re-pin anything to use the Bosch TB on the 3.0T! You will require a special harness that matches the signals (since Conti/VDO uses a different signal than Bosch). If you plug in/re-pin/etc the throttle will still not work. Buy the plug-and-play harness and you will not need to modify anything!
    Owner/Director of Development @ GAS // Garage Auto Sports
    Support performance made locally! -> https://garageautosports.com/
    Mar 19 2021
    Boston
    Quote Originally Posted by Bill@GAS View Post
    When it comes to picking a tune offered, will select for example 034 vdo throttle body file or a stock throttle body file?
    Nov 29 2022
    Ontario, Canada
    For Bosch, select stock a throttle body tune. Jackal is also offering tunes for the Bosch kit we sell but you’ll have to message Tony to provide you one.
