Well, it's either the unit itself drawing excessive current for whatever internal reason, or wires touching. That your fuse doesn't instantly blow every time (no idea if ignition has to be on for it to be powered from that tap) means there's not a short just sitting there all the time. But wires move in a moving car. It's not unheard of for wires to short against something when in motion.
If you really wanted to isolate the device vs the wiring, you'd unplug the device (assuming the wires can be unplugged from it) and mount a ~150kΩ resistor across the plug. Now you've got a static load that produces a constant .1mA current flow (no idea what the specified current draw of that device is) when the circuit is powered. If it shorts again, it's wiring somewhere. If it doesn't short for a week, then it has to be the removed component, the radar unit.
Or test the device by putting it on a 14v power supply with a fuse and let it sit for a week, see if it blows the fuse. But it could be your unit is responding to some input and it drives the current consumption up (because of internal degradation / failure) to the point of blowing the fuse. A static test on a table won't invoke that issue.
In the end, it'll probably be B7's expectation that the device is not robust and starting to fall apart.
