Thought I’d post an update in case anyone else runs into these issues.
Thought about the approach to remove the broken bolts (probably overthought it). Considered the left-hand drill bit/extractor approach but with such a small bolt it wasn’t inspiring much confidence and I had little interest in drilling, and heli-coiling it If the extractor broke. New cobalt bits cored one bolt like it was aluminum - totally worth that purchase. Amazing.
I’d never used the welder I bought at a swap meet years ago but after watching 10,000 videos on YouTube, now was the time to fire it up.
Weld-Pak 100, flux-core, Voltage on “B” and wire speed at about 3.5
Thoughts:
…those settings worked really well
…I’d tried an M6 nut (like 5 times) and it wouldn’t hold. M8 worked much better given more space to fill…big thanks to my wife who in addition to being the fire marshal is apparently a low-key fabricator
…I’d used a washer as it seemed a typical approach BUT think holding the nut with pliers instead would have avoided an issue I ran into. If the washer isn’t flat to the block, when you turn it out you end up with a cleanly scribed arc in your beautiful aluminum block…bolt was OUT but that sucked.
…Aerokroil into the threads just after cooling from red to black definitely helped the situation.
…as all the videos say, back and forth a little at a time to break the bond and you’ll know when you’re home free. What a feeling.
Ouch. There’s the washer scar and the pitting is from putting too much heat into the head (from having to try a few times even though it was the last of three bolts and I should have been a pro by then). Almost made me kick the car off the stands.
Luckily, I’m not the first dope to do this and after another round of research, realized that it isn’t a high heat or high stress area, it was a small wound and there is a pretty typical fix.
Yup. Dug out the dead aluminum with a dental pick, brake clean, acetone and then JB Weld applied with a razor blade to fill in the damage. Lightest coat of ATF on the bolt threads so it wouldn’t bind with the JB Weld. Pretty pleased with the result.
Replaced the aged vacuum lines in front of the intake manifold and once the JB completely cures, we’re back in business.
Cam chain tensioner pads arrive Saturday (thanks @Iksan12 for the rec!)
034 motor mounts
New alternator
New AC compressor
Super Uber Timing kit from Blauparts (but using the all metal 034 tensioner tool!)
I’m sure I’ll be back with questions about the cam timing once I’ve replaced the tensioner pads.
What do you guys use to clean/prep the water pump flange?
