Results 1 to 6 of 6
    Veteran Member Three Rings TheMysticWizard's Avatar
    Aug 15 2016
    '14 MINI Cooper (F56 B38)
    East Bay, CA USA
    Injector Removal and Replacement
    Has anyone replaced injectors on the B9 3.0TFSI / EA839 engine?
    I have a persistent misfire on Cylinder 1. It only occurs at moderate or wide open throttle, higher boost situations.
    I have new plugs and coils. It runs fine at idle or light throttle. Problem occurs on Stock, Stage 1 - 91 and Stage 2 - 91 and E85 files, seems to get progressively worse with additional power output with respected files.
    034 did some logging on it and determined fuel pressure is meeting the requested values and the car seems otherwise healthy.
    Doesn't seem to have excessive gas in the oil. Oil looks clean and normal, no indication of coolant. Coolant level is stable and appears normal.
    Front O2 sensor was replaced about 2k miles ago.
    The fact that it only occurs under heavy throttle leads me to believe the injector is likely clogged. I would like to swap it out with a new injector, however I have never pulled injectors on a direct injection engine. Not afraid to dive into it, just was hopeful someone else had done it previously.
    Tips, tricks, info would be very helpful.
    Thanks guys!
    '15 A3 TDI - Daily
    Malone Stg 2 w/Buzzken DP, Neuspeed CAI, Eibach Pro-Kit, Bilsten B8 Shocks/Koni Struts, Eurosport Camber Kit
    Whiteline Sway, Spulen Links, Neuspeed Torsion Bar, 034 Engine Mount, Dogbone & Subframe Collars, BFI Tranny Mount
    Alzor 349's 18x8 ET35 w/Conti DW 235/40/18, 3mm Spacers
    '18 SQ5 Prestige
    S Sport, Driver Assistance, Dynamic Steering, Cold Weather Packages
    034 Stg 2 E85 Tune, REV9 Intercooler, CTS Turbo DP, VPS Resonator Delete
    Sep 22 2011
    Western MA
    Suspecting an injector issue, have you given your car a heavy dose of Techron? Having fault code(s)? Freeze frame data? Misfires can be tough to solve. Only good news is that it is not intermittent.
    2020 SQ5 Ibis White
    2016 A3 Cabriolet Glacier White 2.0T
    2011 Q5 Ibis White 2.0T (sold)
    2008 A4 Cabriolet Ibis White 2.0TQ (sold)
    2000 A4 Laser Red 1.8TQM (sold)
    Aug 15 2016
    East Bay, CA USA
    Quote Originally Posted by WtA4WtQ5 View Post
    I ran E85 over approximately 7-8k miles in it. Recently switched back to 91 for the last few tanks while trying to solve this.
    I almost exclusively run Chevron.
    Ran a bottle of Lucas injector cleaner through it at about 1/3 tank of fuel, followed by STP injector cleaner the next tank, again when it was at 1/3 tank or so.
    No change.
    Aug 15 2016
    East Bay, CA USA
    Update, seems to be solved.
    I just couldn't accept it might be coils or plugs since I had replaced both less than 5k miles ago.
    Decided it was easier to check that possibility first before moving forward with replacing the injector.
    Pulled the coil on cylinder 1, pulled the plug, everything looked normal.
    Pulled the coil on cylinder 3 and the connector on the coil broke and crumbled off when I disconnected the harness from it.
    Swapped the coil from cylinder 1 to cylinder 3 then put a stock coil on cylinder 1 and went for a drive. Misfires on cylinder 3 now.
    Threw a stock coil on cylinder 3 and it runs like a champ. Beat the hell out of it for good measure, no more misfires.
    Dunno about APR Coils, maybe I got a bad set or they're just junk.
    No real excuse for one to die and one to break apart after 5k miles. Waiting for a response from them now.
    '15 A3 TDI - Daily
    '18 SQ5 Prestige
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    Wow, that’s crazy that one just fell apart.
    iain
    Junior Member One Ring
    Jul 17 2021
    United States
    What would be the point of having the APR ones over factory? I feel like I’ve always read the OEMs have plenty of room left with them.
    2018 SQ5 Prestige | Mythos Black | 034 Stage 2 R2.0 93 Octane Tune | ECS Luft-Technik Intake | CTS catless downpipe
