Results 1 to 39 of 39
    Junior Member Two Rings BenM1013's Avatar
    Oct 18 2021
    Las Vegas
    S3 Front Mount Intercooler?
    Hi all,
    Do you have any suggestions for a front mount intercooler? The only one I can seem to find is the IE one.
    Update: I ended up going with ARM so I'll update with photos when it's done!
    Mythos Black 2015 S3
    Veteran Member Three Rings Eli0073's Avatar
    Jul 17 2020
    USA And Finland
    I'm using Forge.
    Sent from my IN2017 using Audizine Forum mobile app
    Dec 25 2004
    Earth
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Jun 24 2018
    IL
    I used Mishimoto and my hybrid turbo'd S3 didn't have a single hiccup with it.
    2018 RS3 Daytona Gray
    Senior Member Two Rings AudiGeo's Avatar
    Jun 14 2021
    Westchester, NY
    https://www.ebay.com/itm/Intercooler...-127632-2357-0
    2018 Audi S3 8V - EQT Stage 1 93 OTS - EQT DSG Tune - MBRP Catback Exhaust - APR CAI - ECS Intake Hose - Leyo TIP - EQT HPFP
    2018 Audi S3 8V - EQT Stage 1 E85 OTS - EQT DSG Tune - MBRP Catback Exhaust - APR CAI - ECS Intake Hose - Leyo TIP - EQT HPFP
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    I've got the ebay one.. its really well made much to my surprise. No regrets. (And I was a welder/fabricator/machinist)
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Established Member Two Rings fischman's Avatar
    Apr 05 2019
    2006 Yamaha R6
    Colorado Springs, CO
    Quote Originally Posted by Spinnetti View Post
    I noticed the ebay listing says it doesn't include the silicon hose/clamps. Did you reuse the stock or did you need to purchase anything else to make it work?
    2017 A3 P+, EQT Stage 2 (e85) & EQT DSG Tune, Autotech HPFP Internals, Drop In Filter/Removed Snow Grate, NGK Racing Spark Plugs, CTS Catted Downpipe, Carbon Fiber Ebay Duckbill Spoiler, Gloss Black Ebay Lip, 245/35r19 Firehawk Indy 500's on 19x9 et40 Neuspeed RSe10's, Custom Sound Quality Focused Stereo
    Registered User Two Rings
    Sep 01 2021
    Branford / CT
    Hey Ben, We offer a few brands that make intercoolers for the S3 like, I.E., APR, Raclingline & Unitronic. My name is Keven. I'm a retail sales rep at XLR8. I want to help you find the correct part. We stock thousands of parts from many different manufacturers like APR, 034, AWE, Milltek, Scorpion & many more. And we offer free shipping to the cont 48 U.S. on most orders.
    https://xlr8performance.com/search.p...1&category=532
    Feel free to D.M. me or send an email over at [email protected] or call at 203-483-6100 ex 1002.
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by fischman View Post
    Oh, I had aftermarket hoses already - Neuspeed. Mine was also missing little tabs where the ac condenser sits on it at the top. There's a slot for it, but no little cover - I just zip tied that as there is little room for it to move anyway.
    Dec 07 2021
    Columbia, MD
    Got so excited someone might be doing an actual FMIC, then I saw it's all just stock placement...
    Oct 18 2021
    Las Vegas
    Quote Originally Posted by BKozS3 View Post
    I will be doing a front mount in about two weeks. Ended up going with ARM after I hit them up and they said theirs will fit with minor plastic trimming on the front bumper. I'm usuing their charge pipes as well. Buddy of mine is running their intercooler on his IS38 Mk7 GLI and it's great.
    Dec 07 2021
    Columbia, MD
    Quote Originally Posted by BenM1013 View Post
    Ohh this sounds promising. I had thought about going this route or getting an RS3 FMIC and MK7 charge pipes to mate up, but that would be a lot more expensive.
    Sent from my SM-G998U using Audizine Forum mobile app
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The stock replacements are pretty well documented to out perform an actual FMIC on MQB cars. More volume in the core, more surface area, shorter piping, and better airflow to it.
    2019 SQ5 Prestige
    Dec 25 2004
    Earth
    Quote Originally Posted by texasboy21 View Post
    Winner!
    Dec 25 2004
    Earth
    Secret...shhh!
    Dec 25 2004
    Earth
    Also...the lower secondary radiator grills can be opened up for more air flow!
    Oct 18 2021
    Las Vegas
    I'll let you know how it is. The guys at ARM hooked it up and then sent me a dm about 10 minutes after my order went through and said they'd sent everything out already. Pretty excited for sure.
    Oct 18 2021
    Las Vegas
    Quote Originally Posted by MikTip View Post
    Definitely going to do that while I have the honeycomb out!
    Dec 07 2021
    Columbia, MD
    I'm pretty sure most of the FMIC on the market have similar core volume since they are thicker, and I doubt they out perform a FMIC because they don't have better airflow. A stock located IC is sandwiched between the radiator and AC condenser so they heat soak and get air after its passed through the condenser.
    Oct 18 2021
    Las Vegas
    I've heard the same thing that they perform as well as a FMIC, but I wanted to go front mount for heat soak specifically. Figured I'd be better off during the summer out here when it gets up to 110-115.
    Dec 25 2004
    Earth
    Heat soak...the intercooler can only cool down to ambient temps. So if the outside air is 115...then thats as low as the intercooler can go. I have IE intercooler. Zero heat soak issues. However when the outside air temps go over 100...the engine ECU adjusts boost and fueling. It why the colder winter months are called boost months. Adding an after market intercooler will help...however over 110 all it does is reduce intake charge temps to outside air temps.
    Dec 10 2004
    R8_LS400
    Dallas, TX
    ... plus, the big flat plate area of the stock configuration ic cools more than a short thick FMIC where the first part of the core just warms the air as it goes through the fat core.. I'm pretty confident a typical nearly square cross section FMIC will not out perform one of the stock configuration. (I did have a FMIC on my A4, and have no issues on my S3 with the thicker stock config aftermarket cooler on my S3, even here in TX summers). FMIC looks cooler though.
    Oct 18 2021
    Las Vegas
    Ah gotcha. Love your car btw🤙
    Apr 01 2007
    houston texas
    There is a lot of testing and research out there contrary to your belief. Might be worth exploring!
    2019 SQ5 Prestige
    Dec 07 2021
    Columbia, MD
    I haven't looked a ton into this. I have seen that temp drops are quicker, IIRC, on true FMIC vs stock location. Unless there is a limitation of space I am also interested in why the RS# and TTRS use a FMIC and not the sandwiched design of our cars.
    Feb 17 2022
    Elko Nevada
    I can tell you that the CTS Turbo FMIC does not have good fitment. It is cheap, but you are gonna have to fight it for hours and do lots of cutting for it to fit correctly.
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Would anybody who has seen or read how one performs better than the other please link to the source data?
    I've tried my share of ICs, I'd like to see what work others are doing to answer these questions.
    Oct 18 2021
    Las Vegas
    Quote Originally Posted by FlyboyS4 View Post
    Once I get mine put on next week I'll see if I can get some data for you. Not 100% sure I'll be able to though lol.
    Jan 06 2007
    Mk7 Golf R
    FL
    Thanks, I’m referring to the performance difference of stock location vs front mount.
    ARM is one setup I’ve used, I’m just curious to see the results that others have measured, not theories for why one should outperform the other.
    Oct 18 2021
    Las Vegas
    Ah gotcha
    Oct 18 2021
    Las Vegas
    Quick update. The intercooler/charge pipes/turbo muffler delete are all in! Car drives great! I've noticed the power curve is much different now, a lot more linear and feels like it picks up better down low.
    I'll throw some pictures up once I get a chance to clean some stuff up!
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Interesting as a bigger IC takes longer to fill and come up to pressure so slightly increases lag - less rather than more linear.
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    Daniel and DVB2 just announced theirs and should be out in a few months just in time for summer lol.
    Dec 07 2021
    Columbia, MD
    Pics or it didn't happen.
    Jul 12 2009
    2017 A3 2.0T Quattro - hybrid turbo, full flex tuned on Simos Tools/SP, other stuff
    Jan 06 2007
    Mk7 Golf R
    FL
    The change in volume resulting from the IC swap is minuscule in comparison to the volumetric flow rate going to the engine. The differences have been less than run-to-run variation when I have measured boost onset of different ICs. The more linear feel and down low pickup are most likely incorrect perceptions since the ARM IC has a greater pressure drop than the stock intercooler.
    Quote Originally Posted by 2015S3 View Post
    Replace the OEM front crash bar with one made by DBV2? No thanks.
    Oct 18 2021
    Las Vegas
    I gotta find time to switch out my front grille before I take good pics
    Oct 18 2021
    Las Vegas
    [QUOTE=FlyboyS4;14748824]The change in volume resulting from the IC swap is minuscule in comparison to the volumetric flow rate going to the engine. The differences have been less than run-to-run variation when I have measured boost onset of different ICs. The more linear feel and down low pickup are most likely incorrect perceptions since the ARM IC has a greater pressure drop than the stock intercooler.
    I'm sure but it just feels better to me lol
    Aug 14 2020
    Springfield MO
    I have a low mile oem rs3 intercooler for sale.
