Originally Posted by
Z06jerry
I disagree
and so do others :)
The A4's standard suspension and sport suspension struts are the same length compressed and uncompressed. Both suspensions' struts use the same bump stop. The exception is the A4 Allroad strut which is 20mm longer and has it's lower spring perch located 20mm higher up on the strut.
Mostly true. AR is longer.
If you have the standard suspension, you'll want to replace the stock monroe struts. You will also want to measure the mount size in the knuckle. There's two and the common guides were wrong in my application. They all said I had the smaller one for the front struts, but I used calipers and found out mine were the larger ones.
If you increase the spring rate, the monroes are going to hate it. Go with Bilstein B8's, but they are hard to find, the struts are actually shorter and will preload your spring more. Your roll center will change. Lowering will feel good with just springs, but your spine is going to hate bumps, unless you maybe live in the outskirts of fine roads in Phoenix or Vegas.
OP, I had the H&R's, stiff and fun, but too low. Your upper arms will tap the upper well and undo your little inspection covers. Same with the rev springs I tried, which were actually much better than the H&R's on daily driving spring rates. All of them are too low IMHO. Honestly, if you have stock (IBE?) suspension, look for the sport springs on ebay and go OEM+
Ok, I've rambled too much. I swapped suspension several times on the B9 trying a few different combos. I think a lot of Manu's just guessed at what would work on this chassis.
