Originally Posted by
Liquid Smoke
it will be tough to blend it in. i think you can try to just sand the whole thing down so it's even, and then use your own clearcoat to seal it back up uniformly. will be a tough repair though as it's a complex finish, i think if you take it somewhere, a wheel refinishing shop might even be able to do it nicely.
I've done that
I sanded for ages, and it's almost impossible to keep all the grooves parallel to the trim, like the oem trim
Replacement pieces are not cheap
I had wood trim on my old B6 S4 that I had wrapped in dark grey bushed finish that looked great
And because it was vinyl, it was a lot tougher and didn't scratch like the actual metal pieces
It actually had a brushed texture you could feel if you rubbed your hand across it
