Never,
EVER,
ever,
EVER
Flush an automatic transmission!!!!
EVER!!!!!
ON ANY VEHICLE!!!
This has NEVER been an OEM recommended service procedure!!!!!
Back when I did automatic transmissions, at least 25% of the lower mileage rebuilds I did had been flushed in the past few thousand miles!!!!
Think of your automatic as a delicate ecosystem. It has a fluid medium around it, which soaks into all of the components to some extent - The clutches, the teflon seals, the rubber seals, etc.
When you do the OEM RECOMMENDED fluid exchange at the recommended interval, there is a certain amount of "shock" to this system as you exchange older fluid which has broken down to some extent, an advanced fluid with detergent packages, friction modifiers, etc in it, with new fluid. This is the "intended" amount of shock, and within the factory service interval is statistically very unlikely to cause any trouble, ever. The old/worn compounds are leeched out of the porous transmission components over time and replaced with the newer fluid and additive packages.
Now consider when you do the fluid change at an extended interval - You are over the recommended fluid exchange interval by 1.5x... This is more of a shock to the system, however you are still only exchanging a portion of the fluid (which varies by transmission design) - More of a shock, but as long as you aren't way over this interval, or the transmission has been abused, you are usually still just fine.
Now consider the "flush" - Let's say you do it at the OEM recommended "fluid change" interval - Now you are exchanging nearly 100% of the fluid in the transmission. The first time you heat that thing up, you now have a *significant* deviation (from old to new) of your fluid composition, if you are flushing at "OEM recommended fluid change interval" I would not hesitate to guess that this "flush shock" is easily equivalent to the shock from exceeding your fluid change interval by 2-3x, or more!!
This is why many seasoned transmission techs may tell you something that seems to defy logic, but is recommended for the reasons above - If you do not change your fluid at the OEM recommended interval, and instead end up at more than 2x that interval, you leave that transmission alone and never, ever change the fluid in that transmission again. This is especially true for transmissions with synthetic ATF. I would recommend the same - As a transmission rebuilder/tech, I always asked the service history of the transmission, and if someone wanted a fluid/filter change on something which was between 2-3x service interval, I refused to do it. The risk of subsequent transmission failure was too high. The owner was better off caring for the car, not beating on it, keeping the fluid topped off and driving it until problems occurred. On transmissions with synthetic fluid, this often meant they were still fine until 200k miles. I had a family member with a 4T65E in a GM minivan, they changed the fluid at 60k, and then forgot about it until some time around 150k. I recommended that they leave it alone - The 4T65E of this year had some common issues anyway that were bound to pop up sooner or later. Well, left alone and not abused other than the total lack of fluid changes, that thing lasted until 300k when the entire vehicle was scrapped due to rust.
NEVER flush an automatic transmission!!! This is a gimmick invented by companies who sell to these quick lube places to generate more sales margin on useless services!!! Don't do it!!!!
