Results 1 to 20 of 20
    Jan 21 2019
    Denver, Colorado
    Question Audi S4 B8.5 APR vs 034 Motorsports
    Hi guys I have a B8.5 S4 and I currently have a Stg 1 APR tune thinking of doing a dual pulley setup! But, i've been looking into the 034 tune and I really like how that one has the crackle tune, and I would essentially have to deflash the tune and then get the 034 tune for that. Are there any notable differences between the two besides the crackle tune? Also has anyone had any issues with the dual pulley setup for 034? I've heard that APR's setup is pretty good and that people have been running DP on their B8s or 60k miles and above without a problem.
    Would it be worth it to change course and go for the 034? Or ditch the crackle tune idea and go with the DP with APR?
    Feb 16 2019
    miami, fl
    swap to 034 they even have a discount for changing tuners. apr is a dead end for the platform. you don't have to de flash the tune, 034 can write over it.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by wrxkyle View Post
    This.
    Except while you don’t have to de-flash the tune yourself, 034’s flashloader does exactly that for you. Flashes you to a stock file then to their file.
    2007 Porsche Cayman | 5MT
    Veteran Member Three Rings shreddykrueger's Avatar
    Feb 14 2016
    S4 Avant
    Crackle is pretty novel. I had it on with my IE tune for a day then took it off (got annoying FAST).
    If you're going dual pulley make sure you ditch the cats for test pipes otherwise you'll run into some issues (although running test pipes in Denver can be an issue if you're registered here)
    S4 Avant (6MT)
    RCP dual pulley | AWE touring | JHM catted/baffled DP's | AEM water/meth | Ringer Stage III | RSNAV | Vogtland Coilovers | many other tings
    Sep 16 2020
    West Michigan
    I recently purchased 034 files for ethanol support.
    That being said switching from stage 1 to 2 with APR is $150. Their file covers both single and dual pulley.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    You already have a good tune. Switching over to have crackles is pretty juvenile. Don’t be that guy.
    The only reason anyone should switch over from APR is if you want to run E40 or need to change fueling often for racing at the track. That’s literally the only thing other tuners do better.
    People like to dog on APR but the results from actual owners are usually quite different than people think. APR has had a strong 93 tune for 7 years.
    You’re in Colorado so you’re going to need all the help you can get to make power so E40 might not be a bad idea but don’t switch just for the crackle tune 🤣
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Senior Member Four Rings
    Jun 08 2021
    PA
    The only reason i would choose 034 is for the tcu ignition cut at wot shifts and adjustable launch control. If that does not interest you then no point
    Senior Member Two Rings dorothy_c7's Avatar
    Aug 21 2018
    New Jersey
    I like 034 also because of my fan control. If I’m sitting around or in slow traffic it help keep my engine coolant temp low. Heat really climbs in these cars with those factors. For example the constant is 86c and the worst it’ll get is 100c. But the fan can control cuts it back down to operating temp.
    Senior Member Three Rings Slvrbul8's Avatar
    Apr 14 2021
    300zxTT and E46 BMW 330i
    Roanoke, Va
    Quote Originally Posted by Nillious View Post
    What do you mean by "tcu ignition cut at wot shifts"? Does that eliminate the dsg fart?
    Jan 13 2021
    Virginia
    I really like my 034 tune. Its very linear on the throttle and the launch control features are great.
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    Quote Originally Posted by JJM08 View Post
    If you plan to set it and forget it APR will get the job done. 034 has more features like Advanced Launch control, true 0-100% gas pedal resolution , Fans/coolant pump on 100% when stopped (staging mode) , E40 , Multiple Throttle body files , WMI files, Test pipe files, Crackle files that you can control with the car mode and all of it can be flashed at home. Plus their flash loader doubles as one of the best data loggers in the business. So if features and options are something that you value then give 034 a look.
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    May 20 2017
    New Hampshire
    Has anybody got faster times just mashing the pedal instead of using launch control? I think a lot of these features all the tuning companies say their launch control has might just be unnecessary.
    Unless you’re at the track on a prepped surface, just mashing the gas might be faster. Anybody with experience with that?
    Sep 16 2020
    West Michigan
    Quote Originally Posted by EvolutionArmory View Post
    I believe that has been discussed here before. It is called the "upswing method" or something. I have not tried it.
    May 20 2017
    New Hampshire
    Upswing is when you use launch control but don’t hold the RPM at what its set at before you let off the brake. You let off the brake as the launch control RPM’s are climbing.
    I’m just talking about mashing the gas without launch control giving faster times. Mash and go.
    Apr 14 2021
    Roanoke, Va
    Mash and go is slower than using launch control in my experience.
    I tried both using the 0-60 feature on my P3 guage. Best time using launch was 3.6 and 4.0 using mash and go.
    Jun 08 2021
    PA
    The apr and stock software power through the shifts on launch control. No dsg fart. 034 has option to cut ignition on shifts after launch control. Therefore “farting” on launch control shifts and is more forgiving on clutches
    Apr 14 2021
    Roanoke, Va
    Ahh thanks for the explanation. I just installed a Corsa exhaust system and its pretty mellow overall, but the dsg farts are sooo loud now and I didn't like them to begin with!
    I have IE tune and would consider switching if any tuners eliminate the dsg fart.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    The farts slow you down
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Jul 31 2016
    PA
    I have a ZF8 trans, but the difference between launching the car, vs mashing the gas is almost 0.5 seconds. It's a huge difference and the adjustable features are actually a really nice improvement from them. I don't have 034, but things like the cooling fan operation really make a big difference in temps in traffic or while staging.
    Sent from my Pixel 6 Pro using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    May 20 2017
    New Hampshire
    Quote Originally Posted by djn876 View Post
    So you have an A6? Only interested in DSG owners. Some pretty fast 60 foot times have been cut without launch control in the past.
