View Poll Results: Would you buy this mod?
Voters
12. You may not vote on this poll
  • Yes definitely!
    5 41.67%
  • Neutral (Would consider it, but unsure)
    5 41.67%
  • Not my thing
    2 16.67%
Results 1 to 13 of 13
    Junior Member One Ring
    Jul 01 2019
    Question Full Dynamic Sequential Tail Lights for B8.5 A4/S4 Interest Check
    Guys we’re working on making this mod available for all B8.5 A4/S4 owners.
    We will have regular tails that are sequential plus also a start-up sequence/animation module add-on (extra cost).
    For U.S. based people - the sequential kit will include 4 brand new tails (European spec), adaptation harness and coding. It will retail for around ~$1000+shipping (price not final).
    For EU customers we will offer DIY's kits (boards only).
    I need to know how many are truly interested so we can order enough parts for everyone. By interested I mean with money in hand and willing to spend it, not just curious. Parts are expensive, they come from overseas and the boards are custom built by a pcb company. This project will be ready in about ~3 months from today's date.
    I understand the price is high and some may consider this mod “insignificant” but a lot of work goes into this. We will be the first U.S. based company to offer this kit so best believe you most likely will be a 1/1 car rocking this mod.
    Video of finished product: https://tinyurl.com/audia4s4tail
    Video of start-up/shutdown sequence: https://tinyurl.com/audia4s4animation
    Feel free to discuss and post any questions in this post. I’ll do my best to answer all of you. Thanks!
    Veteran Member Three Rings Snowmonkey's Avatar
    Apr 27 2018
    Kansas
    Honestly i would love this, but for me personally the price is too steep. If it was somehow possible to just sell the parts that could swap into existing tail modules or came with headlights too, it might be easier for me to buy. just my .02
    2013 Phantom Black S4, 6MT, APR Stage 1, Carbon Intake, Canyon Run CR-15, aFe Pro 5R, Sport Diff, B&O, Nav
    Oct 05 2020
    C7.5 S6, 4M Q7 3.0T
    Illinois
    Quote Originally Posted by Snowmonkey View Post
    Agreed. $1k is just not justifiable but if we can get it lower by somehow using the existing facelift modules, I’m all in.
    2014 S4 Premium Plus 3.0T
    2016 S6 Prestige 4.0T
    2018 Q7 Prestige 3.0T
    Established Member Two Rings mjessup's Avatar
    Dec 06 2020
    Indianapolis, IN
    this
    2014 S4 B8.5 | Monsoon Grey S4 | DSG | 034 Stage 2+ | AWE Touring + Res DownPipes | RSNav S3 | 190mm Crank 57.7mm Supercharger | Uniden R7 |
    Jul 10 2019
    California
    definitely would buy if it were just plug and play modules like a lot of other cars have
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    I’m in, so long as the final price isn’t worse than this. And I think it would have to be more like $1000 out the door, worst case.
    FYI to everyone else, this is not possible using a plug-in module. The LEDs in the stock taillights are not wired to be individually addressable. You need to redo all the LEDs and add a custom controller with programming to achieve this. Plus separating the lights to add this all in there is not easy and cannot be done safely without expensive equipment (ultrasonic knife). This is not an easy kit to make, hence why no one has up til now.
    Obviously a lower target price would be preferable and I would think achievable for these, but I know how crazy pricing on everything is nowadays.
    2007 Porsche Cayman | 5MT
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Too expensive for this mod.
    and with the large gap between the 2 housings it is very evident that these lights were not designed to have this animation. It just doesn't look right.
    And the startup sequence is very tacky..
    Jul 01 2019
    Not possible to retrofit "just parts" in North American tail lights, only European customers that already own the euro-spec headlights can do it. It would cost way more than this in parts to retrofit American tails to be sequential, not to mention the extra hours of labor.
    Quote Originally Posted by icemen36 View Post
    Please check post above. Price explanation on bottom.
    Quote Originally Posted by mjessup View Post
    this
    Quote Originally Posted by s4Koan View Post
    The plug and play adapters that other cars have (for Audi's) its usually semi-dynamic. Not full dynamic. Can't achieve this with just an adapter, the entire board is replaced and custom built. Audi OEM boards can't be programmed to do this.
    Quote Originally Posted by Ashtonts View Post
    Thanks for explaining.
    Here's an interesting thread where someone's documenting this exact process and price cost references: https://www.audizine.com/forum/showt...il-light-diary
    Unfortunately that's the lowest price range we can do. We leave a margin to run "promotions" or "free shipping offers" but it won't be much. $50-100 tops.
    To give you an idea of the "market value" for the items in this build:
    Set of new euro tails market cost: $800 (eBay / other sites)
    Custom sequential boards: $250 (same price parkes dynamic in the UK used to charge)
    Adapter Harness + Coding (from EU to NA): $400 (Europrice cost)
    Cost of parts shipping TO us, and FROM us: Shipping is $50 domestically to the U.S.
    Labor: 4-6h per set: $400-600 at $100/hr which is what professional shops charge for custom work.
    Total TRUE value: ~$2000+
    The reason why we're making an "interest check" post is because the cost of our boards go down if we order more units. But without enough interest this will be mostly built-to-order and therefore expensive.
    Thanks for chiming in though, your feedback counts.
    PS. You also have to account for your "net cost" to upgrade. Re-selling your OEM tails you can easily recoup $400-500.
    Dec 28 2005
    NY/NJ
    OP, is the start-up sequence/animation module available for the a5/s5?
    Current: 2024 SQ7, 2021 RS5
    Jul 01 2019
    Quote Originally Posted by Kyokio View Post
    I believe you're already the owner of our tail lights (FK) 👀
    The animation is still a prototype and currently under testing, definitely a 3-4 month project... but yes we should be able to do it for A5/S5/RS5 as well.
    Right now we're focusing on just sequential tails, since animations would add an additional cost and the feedback so far is mostly negative about pricing.
    I guess we will stick to a built-to-order basis with a low amount of parts on hand. Mod will remain more exclusive and still available to those that would like to have it.
    Dec 28 2005
    NY/NJ
    Quote Originally Posted by dieGone View Post
    cool, count me in.
    Jun 07 2016
    Any updates to this project?
    Senior Member Two Rings raceshop147's Avatar
    Oct 18 2021
    2012 Toyota Tundra, 2004 Aprilia Tuono R, 2021 Beta 300RR Race
    No way to adapt the us spec lights?
