    Veteran Member Three Rings ElliottG's Avatar
    Apr 30 2009
    '12 Q5 2.0T
    My 2012 Q5 2.0T Complete Engine Rebuild
    Hi guys,
    Haven't had an Audi in a while but I recently picked up this 2012 Q5 that had a knocking engine. PO was a major pig and let it run low on oil. 3-4 years ago this car had a full piston job at Audi, PO bought it soon after that where it decayed AGAIN. I got the car for cheap so I decided to rebuild the engine.
    Before buying:
    Camshaft damage:
    Head damage:
    After taking block apart, scored cylinder wall, block was scrap:
    Making the boring bar setup to repair the head/cover:
    Parts came in:
    Preheating & welding:
    After boring out the welds, then a lot of hand filing ,etc. Not perfect, but will do the job just fine:
    AM pistons ultrasonically cleaned, with new rings:
    Junkyard block got all new bearings for mains and rods:
    Head rebuilt/cleaned up:
    Timing done:
    Going back in:
    First start:
    https://www.youtube.com/watch?v=q9aQotOFdK0
    Running pretty good so far!
    As maybe you noticed, the black Q5 also in the background...also got for very cheap, needed timing chains done to it.
    Veteran Member Three Rings Discipulus's Avatar
    Sep 20 2016
    Portland, OR
    That's a lot of work, nicely done!
    APR Stage 2 DP | JHM 207mm Crank | JHM HX | EPL TCU | JHM Race Pipes | JHM High-Flow Cats | Euro-Spec SQ5 Springs | Bilstein B8 Shocks | 034 Motor Mounts | ECS Drivetrain Inserts | ECS Aluminum Cross Brace | AFE Pro Dry air filter | 034 Silicone Intake Tube | 034 RSB | TRW metal endlinks | ECS Stainless Brake Lines | RSNAV S3
    2015 Q5 3.0T - Current
    2011 A4 6MT - Sold
    Apr 30 2009
    '12 Q5 2.0T
    Quote Originally Posted by Discipulus View Post
    Thanks! Yeah it was a lot of work
    Sep 22 2021
    Toronto, Ontario, Canada
    What did this rebuild run you in terms of budget?
    Apr 30 2009
    '12 Q5 2.0T
    Quote Originally Posted by m4gician View Post
    It was around $1300 for parts but then another $600 for the junkyard block. Total with the head work tooling probably $2000 all in.
    Those are Canadian prices.
    Obviously not taking into account any of the time which was a month on and off
