Results 1 to 25 of 25
    Feb 21 2022
    MI
    Aftermarket Stereos for B6 A4
    So I have been looking at getting an aftermarket stereo unit for my 2004 A4 Avant I have the Symphony sound system with the 6CD changer with cassette.
    My needs for the system are wireless CarPlay and a capacitive touchscreen.
    I saw this…
    https://www.ecstuning.com/b-bremmen-parts/7-android-dvd-multimedia-system/022619brp05/
    At ecstuning but it almost seems too good to be true for the price. Right now wireless CarPlay systems are going for much higher.
    Does anyone have any experience with this unit?
    Also any recommendations for other stereos with the features I listed for under $600 USD would be great.
    Veteran Member Three Rings Darepoole's Avatar
    Sep 29 2015
    B5 A4 2.0 Stroker, 2016 Touareg, 1984 Pontiac Fiero,
    Saratoga Springs, NY
    Quote Originally Posted by obrienb View Post
    I saw this…
    https://www.ecstuning.com/b-bremmen-...m/022619brp05/
    I haven’t use the one you have in the link but it does look pretty sweet very similar to an rnse style wise.
    B5 A4 2.0 Stroker Build (In Progress)
    B5 A4 2.0 Stroker (In Progress)
    Feb 21 2022
    MI
    Yea it looks great, love the design, but I don’t want it to fail in three months.
    Sep 29 2015
    It probably has a warranty but here’s another option.
    https://www.crutchfield.com/p_104BE9....html?tp=72334
    Feb 21 2022
    MI
    Yea I’ve seen this one looking through crutchfield only issues are that I’m paying for the boss system and then an enfig adapter because the wires don’t line up. I think I might just take a chance on the bremmen parts unit.
    Sep 29 2015
    Sweet let us know what you think of the unit after you install it
    Jul 10 2015
    Colorado
    I would probably go with an Xtrons unit instead of the ECS unit. Here's a large thread on the B7 forum that you should at least skim through before ordering something.
    https://www.audizine.com/forum/showt...t-Nav-installs
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    I suggest that you get a unit like this (Ebay): Android 7" Car Stereo DVD GPS Navigation Radio Headunit for AUDI A4 B6 B7 S4 RS4. This looks like a modernized version of Hizpo unit that I bought 4 years ago (pictured) which still works fine, but now with a lot more features. Mine's got GPS nav, but this new one can also mirror-link from your phone, too. For me, the factory-look was important; I didn't want it to look like a rigged-up generic tablet. Works with the Audi steering wheel controls, and comes with the camera too, which I had to order separately in 2018. $233.
    Junior Member One Ring mac85's Avatar
    Jan 13 2014
    Charleston,SC
    I installed a pioneer 7” touchscreen in my b6 A4 using the kit from Enfig Audio and it looks pretty much stock. Even the bezel for the head unit is finished in the Audi matte finish. All the connectors I got from them were plug and play, and the only wire I had to cut was to install the brake bypass. As long as you buy a head unit that has wireless CarPlay that should give you everything you’re looking for. I can post a picture of my install when I get back in town, but it pretty much looks like this:
    Established Member Two Rings Fiction1990's Avatar
    Sep 23 2021
    Las Vegas
    This is the one I have.
    ATOTO A6 Double Din Android Car Navigation Stereo with Dual Bluetooth - Standard A6Y2710SB 1G/16G Car Entertainment Radio,WiFi & BT Tethering Internet,Support 256G SD (No CD/DVD) https://www.amazon.com/dp/B07B3TX6MF...ing=UTF8&psc=1 and I love it, I have my obd2 plugged in and I can use torque on the go, also has my tpms app in it
    09 A4 B8 3.2 lowered on raceland coilovers, 20x8.5 shift spring
    Sold 04 A4 Avant Quattro 1.8T 6m/t, Bilstein coilovers, Magnaflow catback, Hotchkiss sway bars f/r, fmic, hfc, underdrive crank pulley, 18" BBS CH., K04, MTM stg 2, 415cc injectors.
    Feb 21 2022
    MI
    Thanks for the tip these look good, I’m not good with wiring have you installed one? I’m trying to make it completely plug and play no matter how many adapters I need to buy. I’ve also read that you have to shave down the casing on it to fit without interfering with the slots above the stereo.
    Feb 21 2022
    MI
    Yea that’s my issue, everything at crutchfield at the moment that is under $1000 doesn’t have wireless CarPlay. I was actually looking at that Sony unit in the picture with an enfig kit but I don’t want to run a usb cable in to the car. I don’t get the point of wired CarPlay.
    Junior Member Two Rings
    Feb 06 2022
    Nebraska
    I was looking at doing the same thing. I was going to order through crutchfield. One thing that I noticed is they display a warning message that says take great care in installing the double din head unit because once it’s installed it can only be removed by removing the entire dash from the car.
    Is this true? Why would that be?
    Jan 13 2014
    Charleston,SC
    Ski, that's definitely not true. Once the mounting frame for the double din radio is installed, the radio itself can just be removed from the frame like any other radio. The only thing I have to do to get to mine is remove the bezel that came with the kit, and that just snaps on and off.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    The Android model I put in had snaps that once engaged could not be undone. Yea I too the dash apart and found that the clips were hidden. I ended up having to force the unit out mangling the clips.
    Nov 03 2010
    Fallbrook, CA
    I couldn't tell if you have any interest in the system that I linked to, or whether your mind is made up, but here is another description that you can find on Ebay: "For Audi A4 S4 RS4 B6 B7 Android 10.0 7"Head Unit Car Stereo GPS Navigation Wifi". This one is $200, the system does have wireless Apple Carplay and capacitive touchscreen, supports Torque app, and lots more. The only downside for me were the rudimentary instructions (in 2018), which were probably intended for an experienced car-audio installer. The kit included a connector with wiring labeled "A4" which didn't fit my '05 3.0's connector, and another labeled "A3" that did. Once sorted out it worked fine, and doesn't look like a universal aftermarket setup, which was important to me.
    Jan 24 2010
    Paramus,NJ USA
    Still waiting to fit this into my avant when I get a free moment.
    Ziddy Autowerks
    Feb 10 2011
    MI
    Depending how much risk you're willing to take, i bought a chinese android unit off aliexpress. 9" screen, 6gb ram / 128 storage. doesn't do satellite, does do 4G LTE on my carrier, and has been fabulous. I got another line on my account, plugged a sim into the slot and have pandora, maps, youtube, all the normal stuff without tethering a phone. I have a little over 300USD in it. It was plug and play.
    2004 Audi A4 Quattro 3.0 6sp Ultrasport
    2002 Audi A4 Quattro sport "development" car
    2005 Passat TDI Wagon 6 m/t
    1996 Audi A4 Quattro 2.8 (daughter)
    And all the Ford trucks you could want
    Feb 27 2011
    Winnipeg
    I bought a 2gb ram 32gb rom Medeke radio off aliexpress on black friday for $200 shipped, it was plug and play, there were a couple kinks to work out like setting up the backlight to display the correct color, rear speakers not working and buying a radio antenna adapter but for the price I paid it works/sounds awesome, turn my phone into a hotspot and I've got maps, I downloaded all the offline maps as well with out turn by turn navigation.
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Since 2018 been using an Alpine ILX-207 in the B7. Picked up the Enfig surround, harness kit and upgraded mic, easy plug-n play solution. Added a MicroBypass Parking Brake Override to make the unit fully functional at speed. I only use Bluetooth streaming but the Android Auto / Apple Carplay works great (both are wired IIRC). Sound quality is going to be much better than a lot of the Android units and less chance of failure / issues. Looks like there's an iLX-407 out now too, may be worth looking into. Both would meet your budget needs as well, minus the add-ons of course.
    Also worth noting is the quality of Enfig's components + Christian's knowledge and customer service. His harnesses will allow you to retain the factory sub, if that's what you're looking for.
    Any efficient component speakers will be fine with the OEM amp, although it would be best to run em off the Alpine for much cleaner sound.
    Feb 10 2011
    MI
    Quote Originally Posted by seanf86 View Post
    That's the brand i bought too. Medeke/Navifly. Looks and sounds awesome and i had to figure out the couple little issues too, but it wasn't that hard. Definitely good value for the $$$
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by 86turbodsl View Post
    Yea I had to buy a line out converter and do a little rewire and the amp turn on lead was dead, I just tired it to the switched IGN wire, bought a powered radio antenna adapter and it's been awesome.
    Sent from my LM-G900 using Tapatalk
    Established Member Two Rings sleuthnorange's Avatar
    Nov 15 2005
    Ford Explorer
    Waukesha, WI
    Quote Originally Posted by EuroxS4 View Post
    Did you get this finished? Curious to how it turned out.
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by sleuthnorange View Post
    Its painted but not installed yet. When I have a minute I will wire it up on the bench to show how it work and so on. Painted it looks alot better. I will post some pics this upcoming wek.
    Ziddy Autowerks
    Nov 15 2005
    Ford Explorer
    Waukesha, WI
    Sweet! I have been pondering doing this myself. Do you intend on using steering wheel controls to control the iPad? Also have you considered how to use more than just the right and left channel output from the iPad? I was thinking about how to use the 5.1 setup. Is it possible to use an hdmi output to get surround sound?
