Results 1 to 18 of 18
    Veteran Member Four Rings t0mt0m's Avatar
    Apr 26 2005
    Nothern Va
    Angry my car is going to sit for about 5/6 months
    last time i brought it up it got side swiped by an suv and it ran off ..so what are some import things i should do to prep my car for storage?
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Pay for storage... Wax that car to 100% fully clean... and cover it!!!!
    I try to cover my car as often as possible. Cars arn't fully weatherproof and a cover sure as hell helps (WHEN THE CAR IS WAXED)
    Veteran Member Four Rings ArcticBoost's Avatar
    Jun 19 2005
    2005 Arctic A4
    L.I, New York/CT
    ^^ definately a fresh coat of wax then a car cover. make sure the cover is an "enthusiast" one otherwise the inside will scratch the paint.
    Greg
    2005 A4 1.8TQ 6-Speed
    35% Llmuar Tint || 4300K Xenons || Hyper White Fogs || S4 Upper/Lower Grills || Spoiler Depot Lip
    APR Stage 1 v.2 || STaSIS Streetsport Coilovers || Hyperboost Diverter || EVOMS Intake || Strat SSK || Milltek Fullback || APR Snub
    AWE Tuning Pedals || Apline Type-R 12" Subwoofer || Alpine V-Power Amp || Hardwired Passport 8500 x50
    Veteran Member Four Rings roarincheetah's Avatar
    Sep 14 2006
    04 A4 1.8t USP, O2 Chevy Avala
    quick question. Is it being stored inside or outside?
    ~Chris
    Back from Outerspace...
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    +2...
    It really sucks to sit a car for a few month... try to sit it in a place where it doesn't get direct sun/heat, or as low as possible. We don't want to mess with mother nature. lol
    2004 A4
    Central Jersey
    Originally posted by Carlitos
    +2...
    I 2nd that one!!!! But not under a tree or pine tree where the sap will stick to your paint and eat into it.
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Are you going to put it up on jacks? You don't want to get flat spots on your tires.
    789whp
    Veteran Member Four Rings Wilafur's Avatar
    Feb 12 2004
    Los Angeles (Westside)
    drain the oil
    Veteran Member Three Rings h_curtis's Avatar
    pittsburgh
    Not feeling knowledge here on this question. First off DO NOT DRAIN OIL. Secondly fill the gas tank to the top. If you want to play it safe you could add fuel stabilizer, but I don't feel it is necessary. When you back to your car to start it for the first time get the oil changed. You could put it on jacks, but I doubt you will have a problem with flat spots for that long.
    '14 s5, 6sp, sport diff, b&o, panda, estriol blue
    Registered Member Four Rings A4 ABT's Avatar
    Feb 23 2004
    03 A4 1.8T Quattro
    Sunshine state
    Originally posted by Wilafur
    drain the oil
    make sure you put a note/reminder on the ignition not to forget to put oil before starting the car
    '03 A4 1.8t Quattro
    Exterior:USP front w/ Kerscher splitter--ABT sides--Votex rear--S4 trunk spoiler--S4 Door Blades--Euro blindspot mirrors--19" ACE Klassik
    Brakes/Susp.:NS rear swaybar--Audi Sport Suspension--NS brakelines--ECS OEM 3.0L brakes--Hawk pads
    Engine:GIAC K04--Genesis 380cc injectors--Okada CP--AWE Tuning FMIC--APR stealth exhaust--ER Test Pipe--Carbonio V2--Forge Splitter--Forge TIP--NS snub mount--ECS Stage 3 Clutch
    Interior:AWE Tuning Boost Gauge
    Apr 26 2005
    Nothern Va
    ya i just gave the car 3 layers of wax and its staying in my parents garage, gonna head up to school on sat, my bro might drive my car once in a while so i'm not gonna drain the oil, should i disconnect the battery?
    B6 A4 1.8t 5MT Quattro - Sold
    B8 S4 '10 6MT Prem+ - Sold
    pittsburgh
    If you drain the oil you are not too bright. Who ever came up with something that stupid? Oil preserves and need to be in the car. Duh?
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Classic car guys drain oil for long storage. Don't know why, but that is more the norm than not draining. Again, I couldn't tell you why...... IIRC it has something to do with the oil itself getting nasty and contaminated over time.
    Here is something I found on quick google:
    MINIMUM USE OR STORAGE
    We'll break it down into two types of storage: long term and short term. Short term storage is essentially a lengthened period of inactivity. The main question, here, seems to be how long can you go without starting a car before you begin to risk damaging it? And the answer is about 4 weeks. If you let your car sit longer than that without taking special precautions (outlined in 'Long Term Storage', below) you're courting disaster. The internals of your engine, transmission and rear end are bare metal surfaces which are highly susceptible to rust. In fact, they can cease operating effectively if they begin to get even a slight amount of surface rust. They are bathed in oil during normal operation and oil prevents rust. When the car sits, the oil drains off of some of these surfaces. Moisture is the key ingredient necessary for the rusting process and when the bare metal encounter moisture the result is... rust. The less moisture in the air, the less the tendency for rust to occur; dry weather in the southwest and colder temperatures in the northern climes help to ward off rust. High humidity accelerates it. Some so-called 'experts' advise people who don't drive their cars throughout the year to start them up periodically to circulate the fluids and, thus, keep the internal bare metal surfaces coated with oil. While this might seem reasonable, it is the automotive equivalent of the 'old wives tale'. It is exactly the WRONG thing to do. A car in short term storage needs to be driven at least once a month. It requires more than just getting the water temperature gauge off of the peg. The oil temperature should also be brought up to normal operating conditions - and this isn't possible if the car just sits in the garage - no matter how much you rev the engine. You need to take the car out for a drive for about 20 miles or a half an hour. When you go out to the garage to just warm the car up, what you're doing is raising the temperature inside the block - but the engine doesn't run long enough for the engine block to get entirely heated. As a result, when you shut the car off the difference in temperatures (hot inside but cold outside) causes condensation on the inside. Condensation is moisture - and moisture causes rust. A car sitting too long without being run also invites fuel in the carburetor and fuel pump to evaporate, leaving behind a gummy residue. Gaskets dry out are then prone to cracking and disintegrating... more things you don't want happening to your car's engine! So Dr. Hipo recommends a half hour of exercise once a month, every month. On the way back home you should stop off at the gas station and top the fuel tank off... because condensation can also form on the inside of a partially empty gas tank. The oil change interval isn't effected too much by inactivity. Moisture can be collected in motor oil and if it is, it reduces the oil's lubricating ability. Don't be pennywise and pound foolish thinking that you don't have to change oil just because you've only driven the car 250 miles in the past year. Under those condition, an oil change once a year is warranted (although changing the filter probably isn't - you can stretch that to every other year).
    Long Term Storage
    Long term storage is another story entirely. Here, instead of breaking that annual 250 miles into twelve 20-mile drives once a month, you're using the car 250 miles all at once and then putting it away for the next eleven months. Or longer. The way to prepare a car for this kind of storage is to drive it long enough to heat the block (about 20 miles or so) and then change the oil. With the car idling at about 3000 RPM, slowly pour about a half a quart of oil down the carburetor. Be careful not to dump it in all at once - pour it in a slow, steady stream. The exhaust will begin to smoke and the engine may even stall. If it does, do not attempt to restart it. What you've done is to coat the intake and exhaust ports, the valve steams and guides, combustion chambers, piston surfaces and cylinder wall with oil - the very surfaces which are most exposed to moisture - and rusting - during storage. You should then seal the carburetor and oil breathers and back off the valve adjustments until all the valves are closed. This buttons the engine up so that moisture-laden air doesn't get inside the engine - where it would come in contact with with bare metal surfaces. Hit all the nipples with a grease gun (don't forget those hard to-get-to ones on the universals!) and top-off the master cylinder, steering box, transmission, rear end, radiator and fuel tank (and throw in a can of dry gas while you're at it). Remove the battery and move it inside (do not store it on concrete; if you put it on the floor sit it on a piece of wood). Raising the car up on jackstands or blocks relieves the constant pressure on the coil/and or leaf springs and helps keep the tires from dry-rotting and flat-spotting. It also allows you to turn the rear wheels by hand every once and a while to keep the transmission and rear end gears coated with oil. Finally, a coat of wax and maybe a quick once-over for the interior with protectant or moistureizer and you're ready to say 'so long' to your friend before you put the car cover on. Now, you're probably asking yourself one final question: How short can 'Long Term Storage' be? In those parts of the country where winter driving means ice, snow, sand and salt, most Shelby and Cobra are put away around Thanksgiving - or at the first sign of freezing weather. They are brought back out in the spring - after the rains have washed the residual sand and salt from the roads. Four months isn't too short a time for the oil down the carburetor treatment (but you may not want to mess with the valves). -Ed
    --- Following is an alternate set of Long Term Storage tips; compare it to --- the immediately previous directions. --- The author is Manager of Lubricant Marketing, Texaco (Miami).
    >From The Shelby American, #57, Copyright 1990 in response to an earlier editorial response regarding car storage (The Mail SAAC). The Shelby American is a once per year publication of the Shelby American Automobile Club. Copied without permission.
    LONG TERM STORAGE TIPS
    I feel the advice given to your readers on the proper method to store autos for the winter needs clarification. 1. Gasoline tank condensation and water contamination is not a big problem as long as you fill the tank completely with gasoline. Just by limiting the volume of vapor space above the gasoline, in the tank, you will eliminate condensation related damage in the fuel tank. 2. Additives to eliminate water contamination in gasoline should be chosen very carefully as most additive that advertise themselves as removing water from fuel are alcohol-type products. It is true that alcohol will put vagrant water molecules into a solution that will inhibit rust formation in the gas tank as well as making the gas/water/alcohol mixture suitable for burning. What people generally don't realize is alcohol is corrosive to white metals and can do damage to fuel gauge sensors, line couplings and carburetors. 3. The best method of preparing your fuel system for storage is to add upper cylinder oil to your gas tank prior to filling the car and allowing it to mix thoroughly by filling the tank. Pouring oil down the carburetor is not a recommended practice in that most oils' additive package will not burn properly and will foul both your carburetor and your spark plugs. If you feel strongly about providing sufficient lubrication inside the carburetor system, I recommend you increase the quantity of upper cylinder lubricant in the gas tank, and spray the throat and exterior of the carburetor with a light machine oil like WD-40 or a similar protectant after the car has been placed on storage blocks. 4. The most important part of storing the car for a long period is to protect the _cooling system_ from unnecessary corrosion by doing the following: 1) drain and flush the cooling system (including the heater); 2) replace coolant with 50/50 water/antifreeze solution (straight antifreeze is also corrosive and should never be used straight); 3) add 4-8 oz. of water soluble oil to the coolant and run the car until it reaches operating temperature. The water soluble oil will turn milky in the coolant and will inhibit the formation of rust and deposits on the surfaces of the water jackets. Treatment with this type of oil will also inhibit dissimilar metal corrosion that occurs naturally in most engines. If you have trouble finding water soluble oil in convenient package sizes, products such as "Bars-Leaks" are a good source of this type of oil. Regular oil will not do. 5. An oil change to API classification SG motor oil is also recommended. The formulation of SG will keep sludge deposits from forming in engines subject to condensation such as infrequently run engines. I think you will find that your car will come through a long period of storage in much better condition if you try the above techniques. Jim Shields (Manager of Lubricant Marketing, Texaco) Miami, FL
    My 2004.5 APR Stage 3+ is SOLD
    Feb 12 2004
    i guess i am none too bright.......sucka!
    pittsburgh
    I worked in a garage for years and restored plenty of cars. Here is one that sat for over a year. I don't see him saying drain the oil. I read that change the oil. Oil lasts for a year at least.
    http://www.corvetteforum.net/classics/curtis/
    Hey if you want to drain the oil that is your business. Gas should be filled to keep corrosion down like I stated before. Hey, it is up to you what you want to do.
    Veteran Member Four Rings Duchenbagen's Avatar
    Feb 29 2004
    ATL/FLL
    Wax it, fill the tank and then cover it also If it is going to be in the garage you may want to crack a window. You should be fine. Where are you going for 6months?
    John
    USP CLUB MEMBER #5
    How much does the illusion of integrity cost?
    Registered Member One Ring Vox's Avatar
    Jan 31 2006
    '04 A4 1.8t, '07 GSX-R600
    Fort Hood, TX
    If you could have someone drive it like you said... that would be ideal. I've been in Iraq for 10 months and my car has been sitting in my brother's garage the entire time. It was waxed and I put a cover on it. Every week or two my brother will drive it around the block a couple times. Be careful with your insurance if you do this... shit happens and it would suck if you cancelled your insurance and your moron brother hit someone while driving 'around the block.'
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Instead of jack stands just pump your tires up to 50-60 psi. Then when you get back drive it for a few hours like that before you return the pressure to normal.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
