alright, I might need to replace one of the injectors in my bank 1. I have a 2010 car, and it is supposed to use the injectors with p/n 06E906036G. These injectors were discontinued and the new P/N is 06E906036AL I think, which also supersedes 2011+ injector with p/n 06E906036P. Here's the part which got me baffled - these newer style injectors are using different upper and lower support clips p/ns, and to me it looked like the distance from the tip of the injector to the top of the "ears" of the upper injector support element is not the same for the old and new style injectors:
But then I realized I actually had 2 different kinds of upper support spacers I pulled from my new engine when I serviced it before the install (here they're side by side with a new revision support element on the left):
and it looks like the middle support element actually turns out to be the same length:
So nevertheless, I would like to double-check that replacing only one injector with newer revision is fine, and I don't need to install newer style bottom and top support rings to the leftover old revision injectors.
As for that strange upper spacer on the right, it looks like it came from the 2.0T injector, so perhaps when somebody messed with this engine before, they got one or more 2.0T injectors installed
that might explain why the car vibrates at idle and all the spark plugs are looking great except for cylinder 1. if that's the case, then that's crazy. wonder why the car even ran, and ran well at wot.
