Results 1 to 20 of 20
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Head gasket in a bottle
    With the amount of 1.8T cylinder 3 misfire threads in here and the amount of cracked heads on the AMB being the culprit, I'm just wondering if anyone has tried any pour in head gasket sealers? do any of them work? or are they pretty much guaranteed to wreck your motor?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Tried it as a temporary fix. Worked as advertised. Clicky click®
    Veteran Member Three Rings Darepoole's Avatar
    Sep 29 2015
    B5 A4 2.0 Stroker, 2016 Touareg, 1984 Pontiac Fiero,
    Saratoga Springs, NY
    Chrisfix on YouTube did a test with head gasket fluid and it lasted a year or two before it gave out. So like old man said for a temp fix
    B5 A4 2.0 Stroker (In Progress)
    Feb 13 2022
    1985 Toyota MR2 (autox), 2003 Subaru WRX (300whp), 1997 Ford Taurus SHO
    Huntsville, AL
    Quote Originally Posted by TobiqueSlang View Post
    Works as long as you're willing to basically throw the motor out after. I would say don't use it and just replace the head gasket. Idk about the 1.8T motor but I've done a couple of 4cyl and they're really not that difficult.
    Sent from my LM-V600 using Audizine Forum mobile app
    2013 B8.5 Audi S4: DP APR Stg2, 034 DSG tune, ECS Luft-Technik intake, ported throttle body, APR coilpacks, ECS x-pipe and Magnaflow resonator replacement
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by natemail View Post
    Blown head gaskets are a rarity on the 1.8T. The issue is with the AMB head cracking between the valves. 1/2 of a bottle of the Bars 1111 Head Gasket Fix will absolutely fix the problem. I used it successfully to seal my cracked AMB head. After I ultimately replaced the head I sent the cracked one to Kevin C for dissection. Kevin cross-sectioned the head to observe the internal cracks. There were no signs whatsoever of clogging in the head cooling galleries.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Good to know Old Guy. For if there is an need for a urgent quick fix to delay the inevitable.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Sep 29 2015
    That’s impressive
    Jan 24 2010
    Paramus,NJ USA
    I would suggest getting this diagnosed properly before throwing some chemicals into the cooling system that could potentially create a bigger problem than you have. For all you know you have a issue with coil wiring, coils, plugs, injectors or injector wiring.
    Ziddy Autowerks
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by EuroxS4 View Post
    I would suggest getting this diagnosed properly before throwing some shit into the cooling system that could potentially create a bigger problem than you have. For all you know you have a issue with coil wiring, coils, plugs, injectors or injector wiring.
    Agreed. Just run a block gas test to confirm or eliminate a cracked head diagnosis.
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    oh, I've gone over everything. I've already replaced and inspected everything that could cause a misfire and really the only thing left is a head gasket or a cracked head.
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Quote Originally Posted by Darepoole View Post
    I saw it, the sealer didn't even fail eventually he was just done with the car but like anything on youtube I took it with a grain of salt because you never know. there's a big difference between a 4cyl german motor and a 6cyl jag.
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    this is really why I was asking, especially if it's a cracked head. I've had a cyl3 misfire as long as I've owned the car pretty much but it's rare that it happens, usually only after the motor has been cycled a few times(short trips to a few places) never had a problem on the highway or driving distances. car doesn't smoke, doesn't seem to be burning off anything but the coolant always gets low and I've got to bleed the system once every week or so.
    It's not likely I'll be able to get a new head for it any time soon since it's near impossible to find parts for a B6 in maritime Canada, so until I have the time and money to get right into it and find one somewhere else and COVID finally lets up.
    I just wanted some second opinions on whether this could work in the meantime or if it was going to completely trash my cooling system.
    Dec 28 2006
    Western Maryland
    As mentioned above, a block gas test can confirm exhaust gas in the cooling system. It is a simple test to perform.
    Jan 24 2010
    Paramus,NJ USA
    Is the misfire present only at cold start and during winter conditions??
    Ziddy Autowerks
    Feb 27 2011
    Winnipeg
    you don't need to replace the head with one from a B6, theres tons of options for heads from B5s, Golfs, Jettas, Passats
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Quote Originally Posted by seanf86 View Post
    1.8T's in general are hard to come by. There's on scrap yard in the province and they have 2 B6's and a passat and they're both pretty picked over. a head isn't the only thing on my wish list, Ive been trying to find a set of front doors for over a year too.
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    only shows up after 3 or 4 cycles. never on cold start. example being, start up, leave work, stop at gas station, start up, go to grocery store, start up, head to the liquor store, start up, misfire limp it home.
    once it's had time to properly cool down starts up again no problem. it's the only time it happens. I can drive it for hours without a problem, it's just once it's been cycled a few times in a short period that it happens.
    Jan 24 2010
    Paramus,NJ USA
    Sounds like leaking injectors to me or a bad pressure regulator,rather than a cracked cylinder head.
    Ziddy Autowerks
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    as far as I can tell the injectors are fine, I haven't got into the regulator but I will now. I'm going to test it properly before I put anything in it regardless but the plan is to replace the injectors, fuel filter and N80 this spring anyway as well as all the vacuum check valves.
    this car needs a million little odds and ends as well as just some general maintenance parts that have never been changed. it wasn't very well taken care of by the guy I bought it off so it's been a bit of an endeavour. it's due for a timing belt just about so the plan is to do everything while I have the front pulled off it. radiator, j plug, water pump, injectors, seats, check valves, N80. basically everything thats never been changed or that I can change for peace of mind.
    the biggest hang up is getting a set of front doors, It can't pass a safety here because they're a little rusty so there's no sense in doing anything if I can't get those swapped.
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    Bar’s leak got me by for a season before a head replacement. Burning coolant smell on startup and a wet piston was a dead giveaway.
