Results 1 to 11 of 11
    Active Member One Ring Dallydude's Avatar
    Oct 29 2021
    1999 Dodge Ram 1500
    Utah
    ACC misaligned, tried self adjusting, need help.
    Cruise control wouldn’t work, OBDELEVEN stated that sensor was misaligned at 1.43* of misalignment. I took a 3.5mm to the master sensor and made a small adjustment and when nothing changed, a small adjustment to the slave sensor to try to correct the misalignment and now car is throwing 18 various codes throughout the electronic systems (ACC, Central Electronics, both seatbelt pretensioners, parking assistance, gateway, and dashboard) also says auto start/stop is disabled. Should I take it to Audi to rectify?
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Yeah you can't just realign yourself like that. They are not headlights.
    They have special equipment and guides to properly align it.
    Unfortunately it is likely mad expensive. Sorry
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Feb 03 2016
    Cleveland
    I just paid Audi $1000 to do this, it's robbery. They told me it was another $900 to replace the door latch otherwise the ACC keeps erroring out. I replaced the latch myself, cleared the codes, it still doesn't work...
    If you are getting a bunch of new errors, they are probably all of the systems that one error is cascading down through and preventing them from working properly. It likely says something along the lines of function limited due to other faults.
    Senior Member Two Rings Akakios's Avatar
    Feb 05 2022
    2014 Audi S7 | 2018 Audi S4
    DE
    Quote Originally Posted by ItsLarryG View Post
    Yikes, a $1,000 mistake waiting to happen in OBD.
    What exactly do they do for that money? I know they have to cover overhead of speciality machines but jeesh.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    in NO WAY am I saying this will work but since you have already messed with it. . . . .
    https://www.audiworld.com/forums/a6-...tment-2930719/
    Best case you get it right and save a lot of cash. Worst case is you still have to take it to the dealer. Just something I found with Google.
    Established Member Two Rings Nully's Avatar
    Sep 11 2014
    WA, US
    What Valpo A7 posted is correct.
    It's a complicated process and needs a rig to do properly. See: https://www.audiworld.com/forums/q5-...-help-2884003/ around post #9 and #11.
    12 A6 3.0T
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by gk1 View Post
    But the principle is the same? I imagine the expense is because the system is fussy, not because the process is difficult.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Oct 29 2021
    1999 Dodge Ram 1500
    Utah
    Update: every code throw was an intermittent code, same kind of deal when the battery dies and half of the CUs read low voltage threshold. I cleared them all except for the ACC, (those were static) and continued my week as normal and didn’t adjust anything else. Car didn’t show any signs of malfunction. Come Saturday evening, while driving down the highway, I notice I don’t have the fault icon in my dash, I try to use my ACC, and it miraculously works without fail! I was extra cautious when trying the adaptive part of it and covering the brake just in case, and it works as good as it did from the factory! I don’t know how this is possible, because it should only be more out of alignment, but I seemed to have fixed it.
    Oct 29 2021
    1999 Dodge Ram 1500
    Utah
    Please DO NOT ask me for help with more issues with this, because I don’t know how I fixed it.
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Dallydude View Post
    Let us know if it goes out again. Maybe it's on the borderline of alignment. Were you playing Elton John on the radio?
    Junior Member Two Rings
    Aug 10 2021
    Massachusetts
    Ask around at local Indy shops. My local Audi Indy shop referred me to another shop with the proper gear to fully align and calibrate ACC, lane departure, braking assist, etc. Air shock height calibration, 4 wheel alignment, and calibration of all the sensors for $700.
