Results 1 to 28 of 28
    Nov 12 2015
    Oregon
    Stock turbos and E85
    Today someone was telling me he is running full E85 on stock turbos and a completely stock fuel system 4.0t S7. He says you can run E85 on stock turbos and fueling. He says once you go stage 2 or upgrade the turbos that you can no longer run E85 unless you go with Direct Port injection.
    1. Can you infact run E85 on stock turbos and stock HPFP and LPFP with stock lines?
    2. Can you run E85 with rs7 turbos and upgraded HPFP, LPFP, fuel lines and sensors? Or is it required to buy the $6000 SRM intercooler/Di kit?
    I was under the impression that you shouldn't run more then e40 or e50 before the stock fuel system runs out of fuel.
    Sent from my SM-N960U1 using Tapatalk
    My build log
    Established Member Two Rings Evandoe's Avatar
    May 15 2021
    Grandville/Michigan
    The only question I can answer with 100 percent certainty is that you can run full e85 on a completely stock fuel system. Integrated Engineering offers a e85 tune for stock systems. Downpipes and intake are also perfectly fine being ran with e85 on a stock fuel system.
    Registered User Four Rings John@DEADBEEF_DynoSp's Avatar
    Nov 01 2019
    Isle of Man
    1. Yes we have many users that do.
    2. We also have many running RS7 turbos with LP lines and HPFP pistons.
    See DS1 user manual in my sig for lots of detailed info on running ethanol on 4.0T using flex fuel.
    Established Member Two Rings Woodybangs's Avatar
    Jan 08 2016
    MI
    What about a splash of E85 say one or two gallons? I just flashed and want to boost octane on the 93 tune.
    Current: Audi 2018 S6 - DS1
    Former: Audi 2010 S4 DSG prestige - EPL Stage I + DSG tune | AWE intake | Neuspeed exhaust + non-resonated downpipes
    2006 Wrx STI stage II 330hp 315tq | 2005 E55 Eurocharged tune, pulley, headers - Highway monster
    Nov 01 2019
    Isle of Man
    Quote Originally Posted by Woodybangs View Post
    If you don't have an ethanol content sensor, and we recommend you do, you can set the ethanol content manually like this:
    Senior Member Two Rings Djcurb98's Avatar
    Oct 30 2017
    B8 S4 6MT stage 2+
    LI, NY
    I believe it was you and I that was having the discussion until the person who’s comment we were conversing on deleted his comment and our mini thread was gone. For reference I am also running the upgraded lines but as mentioned not fully needed for full E85 on a low stage setup
    Nov 12 2015
    Oregon
    Quote Originally Posted by Djcurb98 View Post
    On insta? Yeah that was me. I was under the impression you needed upgraded lpfp lines and hpfp for e85, but I guess that's not the case. The real thing I was questioning was him saying you could not run rs7 turbos with e85 on stage 2 or 3 software, even with upgraded lines and hpfp. Didnt make much sense to me. He was claiming that it was REQUIRED to have direct port injection for any upgraded turbos... Which makes no sense if SRM sells a kit for running E85 that supports up to 900whp without direct port injection, and only recently started selling the A2A kit with direct port injection. You're not going to see those #s on a stage 1 tune. I dont care who you are.
    I understand that with full stage 3 tune, large than rs6/rs7 turbos, etc, that you may only be able to utilize up to E50 or E60, but on RS7 turbos and lpfp lines and HPFP plunger or upgraded hpfp, you can run E85.
    Not sure why he deleted the comments.
    My build log
    Oct 30 2017
    B8 S4 6MT stage 2+
    LI, NY
    Yah that was me lol I never deleted the comments, we were replying on Someone’s comment and they deleted theirs which got rid of the thread. I was saying you can’t run full E85 on Rs7’s or bigger from what I’ve seen but can still achieve a blend of some sort but I think I also recall in the DS manual that it can become as little a blend as up to e25 I think with the larger sized ones and with getting a system like A2A or some sort of DI you can get that number higher like back to e50 or so but i haven’t seen anything stating that we may be able to achieve full e85 on higher stages even with that system. I could be wrong but anyone else can chime in of they have additional info
    Nov 01 2019
    Isle of Man
    At sensible boost levels for OTS maps with a healthy fuel system, RS7 turbos with LP lines and HPFP pistons can run E85. If we were finding multiple examples where they could not we would refresh our OTS maps to reduce boost over say E70, but we haven't had to.
    Nov 12 2015
    Oregon
    Quote Originally Posted by John@DynoSpectrum View Post
    Thanks John! I figured this was the case, just needed confirmation.
    My build log
    Junior Member Two Rings
    Sep 12 2020
    EU
    Wait, so can I just fill up E85 in a complete stock 2016 S7 ?
    After leaving less than 1 gallon of 93/95/98 RON in the tank and then filling up with E85.
    Or do I need a new ECU Tune but no hardware changes necessary?
    Local E85 Ethanol content:
    Summer: minimum 75, typical value 83
    Winter: minimum 70, typical value 82
    (98 RON is 45% more expensive here at the moment than E85.)
    Established Member Two Rings BluBlur's Avatar
    Apr 25 2022
    2016 RS7 Mythos Black Fully loaded
    GHZ
    wanna know if this is the same for the RS7 as well
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Quote Originally Posted by John336 View Post
    Need an ECU tune to support running E85 on the stock system. No hardware necessary, IF and only if, you can set the ethanol content in the tune, otherwise you will need an ethanol sensor.
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Jun 19 2018
    NH
    Quote Originally Posted by BluBlur View Post
    As John mentioned above - you will need LP lines and HPFP pistons to run ethanol with RS7 turbos; larger turbos require more fueling, which needs larger fuel lines
    Feb 01 2011
    Folsom
    There are situations where you will need larger fuel lines, and high pressure fuel pump pistons even on stock S6/S7 turbos.
    You will get away with it 90% of the time on stock fuel lines, and about 99% of the time on stock HPFP’s.
    However I have seen low mileage stock fuel system, stock turbo cars have their high pressure fuel pump pressure crash on E85.
    It can happen on very cold, negative density altitude weather conditions, on extended pulls going through gears 1-4 and faster.
    Sep 12 2020
    EU
    Quote Originally Posted by MattyMarkey View Post
    Thank you, that's great. Is there a tune that supports 70-85% ethanol content?
    Are there any good ECU flashers cheaper than DS1?
    At the moment I only got genuine VCDS, ODIS & VCP.
    (There's an EDC17 plugin for VCP but it doesn't work through the OBD port).
    Nov 01 2019
    Isle of Man
    We are offering by far the fastest flasher with the best version support, the most widely used ethanol tunes with the best reliability record, flex fuel capability, map definitions, open OTS tunes, by far the best logging of any OEM ECU. We are confident that once you piece together the parts you will spend more and have less capability and reliability. You can buy PCM flash and J2534 to flash most versions for less, but to change the calibration it takes 10 times longer than a DS1 to flash, and the DS1 can map switch and real-time tune, you have no logging, no flex fuel, no map definition, no tune.
    Aug 06 2020
    E85 in higher percentage won’t eat up the stock fuel lines?
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    All nice but not the key factor apparently for John336 who wonders about price. DynoSpectrum sells directly but also through dealers. So far as I'm aware the price is the same, so I'm not sure what value a dealer provides. A purchaser might be able to save on sales tax depending on where the item is bought. In another thread John@DynoSpectrum implied that the "promo code" on the order page is for show only with no plans for anything like a "Platinum Jubilee discount special"!
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Jun 19 2018
    NH
    Quote Originally Posted by Alabama View Post
    Dealers usually offer package discounts with either other hardware or tuning (TCU, Custom).
    They key factor John mentions still has to do with price… buy another tune from a different company and the cost to safely and effectively run E85 with his upgrades, will surpass the cost of DS1 which has everything in one package.
    Nov 01 2019
    Isle of Man
    We are not interested in competing on price, only on reliability, features, quality and support.
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    The Apple Computer of tuning! Certainly the various comments on AZ threads support John's contention and MattyMarkey's comment.
    Feb 01 2011
    Folsom
    Quote Originally Posted by core5 View Post
    It will not.
    Cars have been ethanol compliant ever since fuel went to E10 standard.
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    Not sure on the V8, but you may want to run Ethanol cleaner every fill up, or other. I do I was running E50 on my A6 and the injectors were crapping out.:( I have replaced all 6 when I have my motor replaced then with in 6 months I had to replace two more for leaking
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by ANMS4 View Post
    So if the standard becomes E15 instead of E10, is that enough to require some preventive maintenance?
    Jun 19 2018
    NH
    You definitely don’t want ethanol to sit for more than a couple/few weeks. People will also run multiple tanks of Ethanol and then switch to a tank with only 93 for a period of time to aid in the issues you can run into with high ethanol content in the fuel system.
    Junior Member One Ring
    Dec 31 2019
    California
    I've ran this ethanol stabilizer since 2020 for peace of mind when I converted to e85 on my S6. Every fill up I drop about 2 oz or so, sometimes even more as I just visually gauge it. Heck I've even been running 50/50 water & meth mix with this stabilizer in the tank and have seen no issues in terms of performance or anything. Start ups, idle, WOT no perceivable issues. I have tried other fuel stabilizers like fuel ox and a no name brand and have suffered misfires, perhaps because they don't play nice with either the ethanol or meth. But in summary the Lucas e85 fuel stabilizer is a good product to use if worried about any ethanol sideffects.
    https://www.autozone.com/fuel-and-en...6oz/977411_0_0
    Dec 18 2012
    Framingham MA
    Quote Originally Posted by S6Ralph_Maldo View Post
    Thats the same one I run!! Good your on top of that
