Replacing my battery but looking to go with an AGM battery from Advance since it's cheaper than the OEM battery. Currently have an OEM H9 battery that I installed maybe 5 years ago. Coding it was easy since it has the BEM codes. However, for the AGM batteries without BEM codes, how did you guys code them? Trying to decide between the H8 and H9. The H8 is 95 Ah and the h9 is 100 Ah. The OEM H9 is 110 Ah. Can you I use the current coding or should I use a code that is less than 100 Ah for the new AGM battery?
