Results 1 to 4 of 4
    Feb 15 2022
    raleigh/nc
    Question New rotors and brakes 2015 audi A6 Quattro
    I just found out I need to replace all the rotors and brake pads on my 2015 Audi A6 Quattro and was wondering if anyone can help me out with which ones I should get. Any input would be greatly appreciated. I pasted the link for the set I have been looking into. Also if you have any good or bad experiences with your new rotors and brakes.
    https://www.rockauto.com/en/moreinfo...13824&jsn=3217
    Aug 27 2018
    C7.5 A6 3.0T Prestige
    WA
    While Powerstop kits have been quite good, you will want to upgrade to at least the CRK6130 kit, which gets you the excellent Geomet rotor coating and the carbon ceramic pads. Unfortunately those are usually out of stock, though you can piece the set together yourself quite easily if you are using rockauto. The KC6130 kit is readily more available which gets you slotted and drilled rotors, but there is a price premium.
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    I bought this kit, the akebono pads are significantly less dusty than oem and the drilled rotors look great.
    https://www.fcpeuro.com/products/aud...-4g0615301tkt4
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Also as xanmato noted above, at least get a kit with coated rotors. If not, the hats will rust
