I'm about to pull the trigger on some 19x9.5 et25 wheels for my RS4. I'm fairly lowered on Billstein PSS9 coils w/no fender modifications. I don't want to run 265/30 tires because those will offer significantly less protection from philly potholes/roads. I have the following concerns:
- If I run the 255/35/19 size will it be a lot easier to curb rash the wheels?
- Is the 265/35/19 size likely to run into issues rubbing over bumps and at full steering angle?
- Running 275/30/19 is also theoretically a possibility, but also some concerns about less pothole protection.
If anybody has photos of 19x9.5 on 255/35 tires that show the lip protection that would be helpful. Also, if this is also dependent on tires, feel free to point me to 265/35/19 summer tires that should be the ideal fitment.
Edit: If it matters, I collected some stats from tirerack on their best rated max high performance summer tires:
Yokohama Advan Apex V601:
Section Width = 10.6
Tread Width = 9.0
Overall Diameter = 26.4
Continental ExtremeContact Sport:
Section Width = 10.7
Tread Width = 9.4
Michelin Pilot Sport 4S:
Tread Width = 9.6
Overall Diameter = 26.3
If I understand this correctly, the exact tire specs will have a huge influence on rub no?
