Hello – I think I might have a bad BCM- The car will start then will turn off after a second.None of my key fobs will work-wont lock or unlock anything.They wont resync,I know the batteries are good. The dash/instrument cluster isn’t working properly either. The lights and gauges are not displaying correctly. Im guessing this happened when a portable air pump using the cig socket it had a short across the 2 wires, it blew the cig socket fuse as it should,but I think this happened right about this time. Im not sure though looking at the electrical diagrams.The windows and door locks work manually. Any help would be appreciated. What functions does the BCM do as compared to the comfort control module. If either are replaced do I need to have them reprogrammed? Trying to avoid taking to dealership.I dont have vagcom. One other thing if i order a used BCM does anyone think the symptom would change such as the dash working at least, or car starting
