Results 1 to 10 of 10
    Oct 28 2012
    near chicago
    Get rid of electronic shocks on rs7 or s6
    Has anyone changed the air ride system on the s6 or rs7 to something like coilovers or individual shocks? These cars have bags as well as electro-hydraulic shocks so something would need to be done with the computer to get rid of it and now cause errors. I was thinking you could simply code out the control module via vcds and tell it you have a conventional ride system but not sure. I just hate spending $950 for a single shock.
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    People swap over to coil overs often from air rides, mainly because of cost of repair, so i know that its very doable.
    I've personally never done it, i'm looking to actually put air suspension on my car, but its quite a hefty switch. going to springs/coilovers is much less of a feat but still a lot of work.
    Daily -2015 Audi A7 Prestige| 20% rear & 35% front 3M Ceramic IR tints|Custom Alcantara Starlight Headliner|
    Music, Real Estate, and Audi
    Oct 28 2012
    near chicago
    I don't even necessarily want to get rid of the air ride - it's not the issue. It's the electro hydraulic shocks. One of the rear ones is making a click noise and it's driving my nuts. I just figured for the price of one electric shock I could replace all four with standard shocks. The only issue is you'd either have to code out the control module for the shocks or use a "dummy" device to fool the module into believing there are still electric shocks. From what I gather, it's the air backs that adjust the height but the shocks are what can soften or stiffen the ride. It's a cool feature to change the ride height with a button, but honestly, this not being a "track" car I set the ride to comfort and just leave it there. Don't really need the corner on public roads like a madman :)
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Did you ever look into the Bilstein B4 Damptronic replacement?
    I think they only run about $400
    20-264765
    https://www.bilstein.com/us/en/produ...10577160640976
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Established Member Two Rings tuscani66's Avatar
    Aug 09 2018
    Pittsburgh-PA/Acworth-GA
    I used the OEM part number (took picture of my rear driver side shock as my rear passenger was blown) and found a shock for $210 shipped new on eBay, though maybe you're referencing the front? I can upload a photo of my receipt if you like.
    REAR : 4G0616031AE
    https://parts.audiusa.com/p/Audi__S7...0616031AE.html
    2016 S7 Prestige in Mythos Black over Arras Interior.
    Other Garage Items : Volvo S60 R / Lexus RC F / Saleen S281-Cobra Conv / Porsche Cayenne Turbo S / Toyota Tundra
    Senior Member Three Rings robocop47's Avatar
    Oct 21 2019
    Cincinnati, OH
    The cost, time/labor to convert to static would be tons more than just fixing the issue you have at hand. If you aren’t making some crazy track car, which would probably be pretty sloppy boat still, it’s not really feasible to make the swap
    Senior Member Two Rings Akakios's Avatar
    Feb 05 2022
    2014 Audi S7 | 2018 Audi S4
    DE
    Quote Originally Posted by robocop47 View Post
    This ^
    If you go to sell the car, you’ll find far fewer buyers interested in a converted car.
    Deutsche Auto Garage - Website // YouTube // Instagram
    2014 Audi S7 (Audi Exclusive Interior)
    2018 Audi S4
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    Will you do the work yourself?
    I recently had to do some repairs on my air suspension and was also pricing out alternatives.
    Arnott has a swap kit I believe.
    Lucky, my repair didn't cost much, but if the Oem parts would have been $1500 , I would have switched over to air ride!
    Oct 28 2012
    near chicago
    It's not the air that has the issue, it's the electro shocks. The right rear has made a click since I bought the car and I've just lived with it. It seems to be getting a little louder lately. There's been tons of threads on a "mysterious" noise coming from the rear. I searched and searched - it's the shock (internally). I purchased two of those shocks from ebay for $200 and they were both garbage. Got them on the car and they squeaked/clunked worst than the original I pulled out. The only option for me, really, is OE replacement or swap over to something static. Yes, I do the work myself. I've built tons of cars including multiple older Audis. Easy stuff to change out just INSANE on the prices.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by slowguy View Post
    As gk1 wrote, Bilstein makes a replacement rear shock that FCP Euro sells for $422 and lifetime warranty (but back ordered at the moment). ECS Tuning has in stock for same price but with limited warranty. That's probably as good a price as you'll get for good quality.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
