Results 1 to 11 of 11
    May 17 2014
    SF Bay Area
    Heated Steering wheel and sync button
    Hey all.
    Feel like a dope posting this, but I have read the manual and cannot figure this out.
    1) Is there a way to access the heated steering wheel without going through the MMI on-screen menu? In my prior SQ7 there was a * button on the steering wheel that could be programmed for the heated steering wheel quick access but my wheel has no such button.
    2) I keep noticing that the SYNC button on the lower screen comes and goes. Right now that button is blank, yesterday it said SYNC. Is that a feature? :P
    Established Member Two Rings CanAutM3's Avatar
    Dec 27 2017
    Montreal
    1) You can configure your climate main screen to have the heated steering wheel button at the bottom of the climate screen (the two most inner buttons a configurable). The way to proceed is to activate the axially climate screen on the main MMI, press and hold the steering wheel heating button until you see the screen change, without releasing the button, drag it to either the left or right spot depending where you want it. The main hiccup with this is that there seems to be an MMI software glitch that prevents the presets to stick when the ignition is switched off, so it reverts back to the default when you restart the car. Hopefully Audi will fix this with a software update sooner than later.
    2) I have the same issue where sometimes either the SYNC button appears or sometimes it is just blank. I suspect this is related to the same glitch noted above. There is however one neat trick to work around this: if you simply "pinch" (drag to fingers together) on the Climate touch screen, it will automatically sync the 4 zones.
    May 17 2014
    SF Bay Area
    Thanks for the info. I added the heated steering wheel button in place of SYNC and will see if it sticks. And the tip on the two finger pinch was also super helpful.
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Quote Originally Posted by s4thrills View Post
    Lol. Reminds me of…
    May 17 2014
    SF Bay Area
    Quote Originally Posted by CanAutM3 View Post
    1) The main hiccup with this is that there seems to be an MMI software glitch that prevents the presets to stick when the ignition is switched off, so it reverts back to the default when you restart the car. Hopefully Audi will fix this with a software update sooner than later.
    You were right about this too... when I drove my car again later after making the change, it had reverted back to the blank button. Is there not a current TSB or software update that fixes this issue?
    Dec 27 2017
    Montreal
    Maybe so, if you find out, let us know
    Nov 08 2019
    Houston, TX
    You can also use voice command to turn the heated wheel on/off.
    May 17 2014
    SF Bay Area
    Will call dealer today.
    Quote Originally Posted by Corgiman30 View Post
    You can also use voice command to turn the heated wheel on/off.]
    Thanks for the tip. Will try it out!
    Veteran Member Four Rings FBAnder's Avatar
    Mar 05 2020
    Chicago Metro
    Voice commands are slooooow. Also, don't sing along to any music with Hey, Audi enabled. Don't ask me how I know this.
    Nov 08 2019
    Houston, TX
    Quote Originally Posted by FBAnder View Post
    Yeah voice command for the Nav system is a joke.
    May 17 2014
    SF Bay Area
    I gave the voice command a try this morning and it actually worked! I could care less about heated steering wheel esp in California but my wife will be very happy.
