Hey y'all, been a bit.
Got my car back after it being stuck at a shop for a month, went it for an alignment and wouldn't start on pickup. They eventually found the crank sensor was dirty and spark plugs were fouled, cleaned them up and it runs better for sure. In-fact I believe my crank sensor has been causing issues for a bit now with slightly rough cold starts, bad mileage, and inconsistent performance.
When I got my car back today I went for a long drive to celebrate getting my baby back, about an hour or so I decided to do a 2nd and 3rd gear WOT run to see if it gained back any hp. It did, and in 3rd gear after about 3500 rpm when my engine was in the better part of the power band; the rpms climbed quicker than normal to around 4K rpm during peak boost and held there as I kept picking up speed (think CVT behavior). After a second or two I let off realizing what happened, it's around -1C or 30F and it definitely gives my car more power as it has the stock SMIC and suffers heat soak but, even so I feel I shouldn't slip with the stock turbo. I always drive in tiptronic mode so the TC is usually locked over 30km/h, and it's noticeable when it slips.
Now I'm turning to you smart folk here on this forum that might know a thing or two about running more power reliably on a tiptronic. Is this really the limit of the stock transmission and TCU tune? or are the clutch packs going. Car has about 230,000km (143,000 Miles) and I don't think the transmission fluid & filter has been changed, I at least haven't done it for as long as I owned the car (6 years this March) out of fear it'd start to slip at the mileage it's at. Yeah I know, not the best thing but, I don't have disposable income in-case messing with the fluid causes issues even though not doing it can also cause issues. I was planning on a tune to run higher oil pressures for the clutch packs since that could help prevent slipping, and doing a fluid drain & fill initially after that.
Anyways enough of my ramblings, I appreciate any of you guys who can chime in! I plan on hitting the 300hp mark reliably so I definitely need to take care of this issue first... or maybe bite an expensive bullet and get a shop to do a 6spd swap lol.
