Results 1 to 40 of 66
    Established Member Two Rings smatch's Avatar
    Dec 24 2021
    Rio de Janeiro / RJ
    P3054 jammed or eletrical starter module
    Hello
    Audi A4 B8 2.0 TFSI
    stopped running no drive
    Only one error in VCDS
    P3054 starter module jammed or mal function eletrical
    Vídeo problem https://streamable.com/9tm6qi
    Only this error on VCDS, but I try run crankshaft by hand with 24mm and is impossible.
    Sound like starter module? Fuses all is ok!
    Thx all
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    Yeah either starter is extended and wedged in the ring gear, or the engine is locked up. Hopefully the former
    Feb 15 2016
    Cambridge,Ontario
    I would say more likely engine is seized.. you dont state how many km on it ..
    obvious next step , remove starter see if crank frees up
    I hear of lots of engines seizing, very rare to hear starter motor " jammed it " even if it was stuck on, the motor would just turn the starter and burn it out.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Dec 24 2021
    Rio de Janeiro / RJ
    Quote Originally Posted by apeck240 View Post
    Is there any way I can test the starter motor to see if it's the same? without dismantling it
    Apr 01 2021
    Quote Originally Posted by smatch View Post
    Uh pull the starter out. You're either doing that or pulling the engine out
    Dec 24 2021
    Rio de Janeiro / RJ
    Oh sorry
    It has 134000km.
    The starter motor has already been replaced with 60000km.
    the engine has been redone all the way up and the bearings have been changed recently.
    I was on the track, the car was going very well, until it turned off walking at 50km/h in a roundabout.
    and it was as shown in the video.
    Is there a way I can test without having to remove the starter motor?
    Apr 01 2021
    Oh sorry
    It has 134000km.
    Sounds like you were low on oil, it all slung to the side of the pan and sucked air and locked up. No, pull the starter out
    Apr 01 2021
    Also I didn't see there was a video, sounds like the starter is functioning, that's bad news
    Dec 24 2021
    Rio de Janeiro / RJ
    No, I Think oil no is faulty, This is showing MAX on panel oil level.
    Dec 24 2021
    Rio de Janeiro / RJ
    Sh*t :(
    Very had
    I going to test relays now, otherwise I send the car to dealer mechanical profissional again :(
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    grab a ratchet and try to turn over the engine. I say try because your engine is seized.
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Apr 01 2021
    I'd be on the phone with whoever rebuilt your engine if I were you
    Apr 30 2018
    DFW, TX
    ^^^^THIS^^^^^
    WPT+
    Dec 24 2021
    Rio de Janeiro / RJ
    I called my mechanic and showed the video, he said it's not a locked engine. but he has a schedule full of cars and can only move on the 5th of March.
    Dec 24 2021
    Rio de Janeiro / RJ
    Quote Originally Posted by bb-tt View Post
    On the crankshaft? I tryed this… with 24mm ratchet… impossible turn crankshaft only move 3cm, by hand
    Dec 24 2021
    Rio de Janeiro / RJ
    This is confused me because on VCDS only show P3054 starter module, lol.
    I didn't hear any metal noises or smoke when it stopped
    Apr 01 2021
    I don't know what more you want from us, your engine is locked up. Maybe pull the drain plug and see if any cool stuff falls out
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Try turning the engine counterclockwise just a very little bit. If the starter is jammed this may free it up.
    Dec 16 2017
    Oregon
    Just to add to this, pull off the accessory belt and pull the spark plugs. If in neutral and it wont turn, you have some larger problems
    Apr 30 2018
    DFW, TX
    Quote Originally Posted by beatsageo View Post
    You can hear the starter engage and disengage in the video if the pawl gear is not stuck he probably spun a bearing or worse
    WPT+
    Dec 24 2021
    Rio de Janeiro / RJ
    I believe it could be something in the starter motor since the VCDS only accuses this error.
    the starter motor bearing must have seized or broken.
    since I tried to start as soon as the car stopped, with it in neutral and started it and lightly.
    I think, tomorrow I'm going to take it out, and then with it, the first thing I'm going to do is try to turn the engine through the crankshaft, if it turns I'll be very strange.
    I really thank you só mutch for help me!!!!!!
    Apr 01 2021
    There is no code for the engine locking up. If you try to start a seized engine, the starter won't be able to turn and will give you that code. Good luck
    Feb 15 2016
    Cambridge,Ontario
    He said earlier it won't move at all with a wrench
    But some data is bad. Also said he can't move it with crank, then said it will move 3cm. Who knows if it was in neutral when he tried to turn it.
    Personally I think taking one of these engines to the track is asking for trouble.. as they barely hold together going to the grocery store
    But he have to wait for the mechanic if he has not pulled the plugs and put it in neutral to see if it will turn over. Balance shaft seized if it's not a main bearing.
    Sent from my Pixel 6 using Audizine Forum mobile app
    1976 Yamaha XS 360
    Dec 24 2021
    Rio de Janeiro / RJ
    yes guys
    I took out the starter motor and the crankshaft did not go by hand.
    I won't wait for the mechanic who made the engine until March 5th lol.
    I believe I will disassemble the front of the car and start inspecting the balancer shafts.
    a doubt I have is, if it's not the balancer axes and something locked the crankshaft such as (bearings), can I take the crankshaft out or change the bearings doing the work under the car? I don't have an elevator, lol.
    thanks again everyone's help.
    Apr 01 2021
    yes guys
    No, engine out to get the crank out. I suggest you don't attempt that yourself
    Feb 15 2016
    Cambridge,Ontario
    yes guys
    okay so far it is exactly as I had suspected.... you can NOT remove crankshaft from under the car.. the engine must be removed as the RMS flange fastens to both the block and oil pan .. so engine or transmission has to come out.
    The next step as you say is to remove the front timing cover ( upper and lower ) , release the tensioners and remove the crank sprocket. this will release both the timing chain and balance shaft chain from the crank. you will know immediately if you have a siezed crank, seized balance shafts, of failed timing components... ( you can probably do it by just looking at the chains but probably best to just get it all off )
    Id be going after that engine builder if i could , but we need more details about that .. first things first
    1976 Yamaha XS 360
    Dec 24 2021
    Rio de Janeiro / RJ
    Omg Thanks advanced
    I need search other mechanic lol
    Here on my region brazil citys dont have much specialists on EA888 :(
    Otherwise Thanks so mutch
    Dec 24 2021
    Rio de Janeiro / RJ
    I managed to remove the starter motor.
    the engine by the crankshaft is only turning counterclockwise now.
    schedule it does not rotate.
    Feb 15 2016
    Cambridge,Ontario
    Sounds like timing failure.
    1976 Yamaha XS 360
    Dec 24 2021
    Rio de Janeiro / RJ
    my battery is dead, i will test the starter motor in hand on another battery.
    and see how he is.
    If he's okay, I'll start disassembling the front myself. f*ck
    do everything calmly until you try to find this problem.
    I just won't be able to do it at home if something happened to the crankshaft bearings etc.
    but the motor runs counterclockwise.
    Dec 24 2021
    Rio de Janeiro / RJ
    Starter motor tested, working.
    should i remove the front to check balancer shafts and current without the starter or can i put it on first? I say because the engine is loose with a support holding it, due to having removed the engine support cushion.
    Feb 15 2016
    Cambridge,Ontario
    dont try and turn it anymore until you get the front timing covers off and see what is happening.. dont bother with the starter, im telling you thats not it.. unless of course you burned it out trying to start the car....
    if you cant turn it with a big ass wrench then its jammed for some reason so the chains interlocking it all are next..
    1976 Yamaha XS 360
    Dec 24 2021
    Rio de Janeiro / RJ
    OK
    thank you so much
    I should dismantle the front soon.
    thanks
    Feb 15 2016
    Cambridge,Ontario
    you don't have to completely dismantle it , just have to pull it forward some .. there used to be a good you tube vid. let me see if i can find it..
    https://youtu.be/DihEegHWaYM
    1976 Yamaha XS 360
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    There is also this. I used this video to do my chains this past summer.
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Dec 24 2021
    Rio de Janeiro / RJ
    thanks for information
    I already removed the front as the colleague's video showed.
    I locked the crankshaft pulley and I'm trying to take the bolt out of it, I'm giving more than 20 kg of torque to loosen and it's not going! omg
    someone has seen this.
    the pulley bolt is extremely hard...
    Feb 15 2016
    Cambridge,Ontario
    Yup ... It's a stretch bolt ..
    Sometimes takes two . One to hold, one to unbolt
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    Any reason against using an mid power impact to tap it loose?
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Smac770 View Post
    They are a one time use only bolt anyway so absolutely not . Sometimes you don't have the access to get the gun in, or the gun doesn't budge it. But otherwise nope.
    1976 Yamaha XS 360
    Dec 24 2021
    Rio de Janeiro / RJ
    Hello theiceman, and everyone who is helping.
    I managed to remove the crankshaft pulley bolt.
    And I think I figured out why I was so stiff, I needed help from a friend and we used our 2 strengths.
    The screw for it to come out to the end was hard, and I'm sending a video showing the chain kit and also a problem with the crankshaft pulley screw.
    The screw now doesn't go all the way, it doesn't tighten, in the video I show it.
    I think here's the problem, in the chain I didn't find any problems, but for now I haven't dismantled the timing chain.
    Look at the video and see what the crankshaft pulley bolt looks like, and through his experiences, what might have happened.
