Results 1 to 13 of 13
    Oct 23 2017
    Durham, NC
    2020 RS3, early upshifts during launch control
    Hi all, I have a 2020 RS3 with Unitronic Stage 1+ ECU and Stage 2 TCU software installed. I've only used launch control a couple of times since I purchased the car. Today I tried to launch the vehicle, in Dynamic/Sport, and the car upshifted to 2nd at 4-4.2k rpm. I let it cool for a few then tried again and it did slightly better but still shifted early compared to the other times I've tried to use launch control. Anyone else experience this before?
    Junior Member One Ring
    Jan 25 2022
    2018 Audi Q7, 2016 Toyota 4Runner TRD Pro
    Colorado Springs
    I have experienced the same. I have the Unitronic Stage 2 ECU along with TCU Stage 2. I haven't used launch control (have only had the car a couple of weeks) but have floored it when in 1st gear and have also noticed early upshifts to 2nd. I assumed there was a reason for this and looking forward to any insights others can offer.
    Mar 22 2012
    LOS ANGELES, CA
    Either you have tire slip or you don't have traction control all the way off.
    Dec 12 2021
    New york
    Out the Esc in sport or completely turn it off by holding it problem solves. I always run esc in sport, the traction control is way to sensitive
    Oct 23 2017
    Durham, NC
    It's one of the first things I do when I turn the ignition (turn ESC all the way off- long press/hold of the button until you receive the notification that it's "off"). And no tire slip; nice dry roads, brand new tires, no sound of slip. It's strange.
    Feb 18 2019
    Quote Originally Posted by hawkbyte View Post
    Are you launching in Manual and it's still upshifting early? (1st to 2nd auto upshifts even in Manual but should run up to redline). Which Stage 2 TCU file are you running? Try one of the rev1e TCU files.
    Oct 23 2017
    Durham, NC
    Quote Originally Posted by hberg002 View Post
    I have the Unitronic Stage 2 (rev1e3) file installed. I launch in S-Mode/Auto and then shift to manual after the 2nd-3rd shift.
    Oct 08 2021
    Uxbridge MA
    Uh, why? Just use manual mode from the start.
    Junior Member Two Rings
    Jan 26 2015
    trinite
    I am going back a ways but I had the same 1+ (E85) stage 2 TCU in mine
    I got better times putting the transmission in sport and letting the car shift itself. I think I got a 3.03 0-60 on my winter setup
    I would run into the same thing you did but I started launching at lower RPM and did not let the boost build all the way up to get the best and consistent results
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    To the OP,
    That has happened to me 20% of the times or more with the traction control completely off. It has to do with spinning the tires
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Nov 11 2021
    Atlanta, GA
    I tested mine (stock tune) several times yesterday and found that if you put it in manual mode and do launch control, shifting 1-2 on your own, it will always hold the gear even with wheel slip if the TC is completely off/etc. Just shift it over to auto after the 1-2 and voila, no more short shift launches.
    Feb 18 2019
    Maybe not related but I would definitely try out the rev1e or the rev1e2 file as they are more aggressive than rev1e3. Also, just launch with the car in Manual, it auto upshifts 1st to 2nd anyways. Then you'll just have to worry about 2-3 and on.
    Jul 10 2020
    I've noticed this both stock and APR Plus tune in my 2020. Using launch control and manual mode shifting I find maybe 25-30% of the time it shifts early from 1-2. Once or twice I've experienced it in 2-3 as well.
    2020 /RS3 Nardo Edition | 15% 3M Ceramic All Around | CeramicPro cermicoating | HRE FF11 19x9.5 | 034 Rear Sway Bar, Endlinks | Eventuri Stage 3 Intake | APR Plus Tune | APR FMIC
    2015 STi Limited
    2006 Legacy GT Limited
