My 2015 Audi Prestige Supercharge now has 111K Miles.
I want to know the current condition of my vehicle and how many miles it has before giving serious troubles. Currently it drives great with no codes.
I took it to the shop and here is what they quote me, although they said theses are pretty normal wear and tear for a car with 111K Miles.
Report:
- left and right Engine mounts needs replacement
-Transmission mount is leaking hydra fluid
-Control Arm Bushings broken, upper bushings need to be replaced
-Coolant is slightly leaking from water pump
-Rear Shock Absorbers have leaked hydra fluid and needs to replaced along with rear shock mounts
-All Tires need to be replaced, some are repaired with putty and putty job can not be further repaired.
